SOLD Blackstar HT100H MK III inc 6 Way Footswitch £425 posted
kennedydream1980kennedydream1980 Frets: 1266
edited March 2025 in Amps £
Moving this beast of an amp on to fund other gear.
Extremely versatile amp. 3 channels on this with 2 modes on each channel. Can go from crystal clean to extremely high gain.
Runs on 2 ECC83’s & 4 EL34 valves. Can run at 100w or 10w.
The added bonus with this amp is it has an in built reactive load with direct outs (XLR & 1/4 inch Jack) running Blackstars proprietary Cab Rig software. You can change cabs, mics, eq, reverb types etc using Blackstars Architect software on your Mac / PC. The amp connects via USB C. You can turn the cabs off and run into an IR loader if your prefer to use your own IR's.
The amp can be left on standby and ran direct, which is how I've been using it. The in built cabs sound excellent.
The amp itself sounds epic. It’s lived a very easy life in my home studio. It’s never been plugged into a cab. I’ve only ever ran it direct to my mixer and through studio monitors. It's in excellent condition.
I’ll include the 5 way footswitch which allows you to access all 6 modes, turn the reverb on and off and click in a 6db boost on any channel.
I don’t have the original box but I do have access to sufficient packaging to post it.
£500 inc postage.
