Fiddle Pro Mic £115
guycpguycp Frets: 39
edited March 1 in Studio & Rec £
The Fiddle Pro £125
Bought in 2012, but never used. As new condition with case and spare lead.
Violin/Viola Microphone System
Read Instrument Microphones
A professional quality microphone with the simplest fitting available
Can be quickly adjusted to fit all sizes of fiddle and viola
A directional hypercardioid microphone in close proximity to the instrument
captures maximum sound level while minimizing the risk of feedback.
The microphone is rotated to a position over the sound hole.
The Fiddle Pro connects direct to mixer or PA microphone input.
Internal electronics provide power management, impedance matching and balanced output.
Operates from the 3v on-board coin cell, or 48v phantom power if available.
Fiddle-Pro Specifications
Microphone type:..............................................Unidirectional back electret capsule
Directional Pattern: ...........................................Hypercardioid
Principal Direction of Sensitivity: ......................Downwards towards the f-hole
Microphone Sensitivity:.....................................3.2mV/Pa (-50dB)
Microphone S/N Ratio: .....................................>58dB
RIM
Frequency Response: ......................................100Hz to 15kHz
Output Impedance: ...........................................600 ohms
Output Level (nominal): ....................................-10dB
Power Requirements:.......................................Phantom Power (11 to 48 volts) or Battery
Battery: .............................................................3 volt Coin Cell- Varta CR1220 or equivalent
Connection Type:..............................................3-pin Male XLR for connection to
‘Microphone Input’ on P.A. mixer
Output:..............................................................Balanced Signal (hot + cold + ground)
