What’s a good USB interface for amp capturing?
I have a presonus interface but it doesn’t work for amp capturing because you can’t split the L/R outputs to only output one input. Both outputs always output both inputs. Which results in nasty feedback through the amp!
  • grungebobgrungebob Frets: 3735
    The tonex one is pretty cheap at £148.
    Don’t know if it’s any good though
  • gearaddictgearaddict Frets: 917
    That’s not an interface though, is it?
    It’s a capture device and re-Amper.
    Yeah - so you still need an interface, right?
    You could use it with your current if you only need mono.
    The problem is my current one doesn’t work because you can’t route the separate the outputs.  They always output both inputs. That means the mic feed is routed back through the amp, resulting in feedback. So I need an interface that allows me to route input 1 -> left output and input 2 -> right output. Or similar.
    Ah gotcha. Right. I’ll butt out.
    Ah...actually I think you are right, having looked at how the Tonex Capture works. Looks like I would only need a basic interface to work with it and mine would probably do.  =) Might be worth a punt.
    Hurrah
