LOL 0
Wow! 0
Speaker pole with one of the tops above it, the other top on a regular speaker stand.
If you feel like you need more add another but chances are you'll be fine.
We use a single sub like that for some mid size venues in one outfit I play in.
It should be as easy as going from your mixer left and right to your sub in left and right, then left sub out to the left top speaker and right sub out to the right top speaker.
1 sub plus 2 xlr cables and you're good to go.
I have a couple of 12” EV elx200-sp subs which I use under either Yamaha dxr8s or dzr10s, depending on the gig.
The band I worked with for the past few years had a Dynacord A series system, 12” on tops and 15” subs. When I swapped it out for the dzr10/EV12 rig there was no lack of volume/coverage, bass was much tighter, not quite so low but punchy.
Easy enough to carry one in each hand, but not for too long.
