Haych
Frets: 8537
There's a piece of Nerina in every song that I sing
Bit of trading feedback here.
LOL 0
Wow! 0
Is that what you meant?
https://www.theoddfoxes.com/
There are a couple of dozen other posts on this topic from me here.
1. The room you mix in is as important the the monitors you use. Spend half your monitor budget on room treatment.
2. There isn't much under £1000 that I would personally mix on. Exceptions- Genelec 80x0 series, Dynaudio BM6a's (used)
3. Room correction can help but doesn't replace 1.
All the monitors under £600 is roughly equivalent in terms of what it can do- there will be trade off's regardless of which way you go.
4. Larger bass drivers are a bad idea if you don't address 1.
I would personally prefer to mix on a 4 or 5" bass driver in an untreated room and try to sort the low end with headphones than try to mix with a 7" or 8" driver.
There is more I could say on this topic- a lot more really, but I'm tight on time right now.
Oh, finally- yes, you can learn your monitors and learn to mix in any room., or learn your room and mix on any monitors etc.
That takes years and years of experience though.
To give you an idea- I've been doing it for 30 years and it is only in the last 10 or so that I feel comfortable to say I really
know what I am doing.
So, in short, nothing in the price point of the HS7's is above and beyond better than any other option, including the HS7.
I would go for smaller bass drivers if you aren't (and I assume you won't any time soon- because almost no one really gets this bit until they actually try to mix for release) going to treat the room.
