Brio
Frets: 3581
LOL 0
Wow! 0
PS. Google AI says - To relocate the Logic Pro for iPad Sound Library to an external SSD, you'll need to use the "Relocate Sound Library" feature within Logic Pro. First, ensure you're logged into your iPad as an administrator. Next, connect the SSD to your iPad via a USB-C cable (or with a Lightning adapter for older iPads). Then, open Logic Pro, go to "Sound Library > Relocate Sound Library," and select your external SSD as the new location. Logic Pro will then move the Sound Library to the chosen SSD, freeing up space on your iPad.
I've no idea if this is good advice as I do not use Logic.
