- Notable tone suck from each pedal. Exacerbated when both are used in momentary mode (which, lets be honest, most would want to do)
I had really high hopes as well. I appreciate I could put them in an isolated loop which is only engaged as needed to get rid of the tone suck, but the unnatural cutout on the FreqOut doesn't make it worth it. Plus it would then require two button presses to engage either effect (one for the loop pedal, another press on the pedal itself), and in this case you really want a quick response due to the way you want the pedals to immediate manipulate the signal.
Both are being returned as a result, unfortunately. Unfortunately, none of the reviews I watched on either pedal mentioned the issues.
Playing in punk band on guitar - it would be dead handy to have usable feedback on tap.
I suppose you have to think of it as 'simulating' feedback, it's not in a constant loop with the guitar and amp. (Although I should probably try it again at high volume, to see if that changes how it works.)
There needs to be a signal from your guitar above a certain threshold for it to latch onto. I had a quick go just now, and with a big open string note, I can get between 15 and 30 seconds of feedback effect quite easily. But you're right, once the guitar level into the pedal goes below the threshold, it does cut off quite abruptly. I've seen a few mentions about this online too, but I don't find it too much of a problem.
My favourite mode is 'low natural', I think that sounds pretty realistic.
I'd also like to nominate the Jacques Trinity and Exar Multiwah (which are closely related). Envelope filter with LFO and a little lilo-pump-like foot controller. And you can have all three working at the same time, so as the envelope dies away it goes to the foot control position, and as you release that the LFO comes in.
Make sure you don't forget the riff to Stranded by Gojira (only one octave up). That's also addictive
