SOLD Charvel Pro-mod San Dimas Style 1 HSS FR Aqua Flake £500 posted
kennedydream1980kennedydream1980 Frets: 1267
edited August 2025 in Guitars £
As new Charvel Pro-Mod San Dimas in the very eye catching Aqua Flake finish.
Picked this up recently but it’s a bit too modern sounding for me. I tend to reach for one of my vintage style strats as a preference.
It’s in immaculate condition and comes with the Charvel Gigbag.
Back plate, Trem arm, paperwork and hangtags all included in the sale.
Photo shows coins wrapped in tape lodged in the trem cavity, I had these in there as a pseudo trem block. These will be removed and the trem set to float as per the stock spec prior to shipping.
£600 inc postage.
Now £500
Pics: https://imgur.com/a/fGfz8I7
Full Spec:
GENERAL
Model Number 2965033513
Series Pro-Mod
Color Aqua Flake
Number of Strings 6
Orientation Right-Hand
ELECTRONICS
Bridge Pickup Seymour Duncan® JB™ TB-4
Middle Pickup Seymour Duncan® Custom Flat Strat® SSL-6 Single-Coil
Neck Pickup Seymour Duncan® Custom Flat Strat® SSL-6 RWRP Single-Coil
Pickup Color Black
Controls Volume, No-Load Tone
Pickup Switching 5-Position Blade: Position 1. Full Bridge Pickup, Position 2. Bridge Inner Coil and Middle Pickup, Position 3. Bridge Outer Coil and Neck Pickup, Position 4. Middle and Neck Pickup, Position 5. Full Neck Pickup
Pickup Configuration HSS
BODY
Body Finish Gloss
Body Shape San Dimas® Style 1
Body Material Alder
HARDWARE
Bridge Floyd Rose® 1000 Series Double-Locking Tremolo (Recessed)
Hardware Finish Chrome
Tremolo Arm Floyd Rose® 1000 Series Locking
Tremolo Block Brass
Tuning Machines Charvel®-Branded Die-Cast
Control Knobs Knurled Flat-Top
Switch Tip Black
NECK
Neck Material Maple
Neck Construction Bolt-On with Graphite Reinforcement
Neck Finish Hand-Rubbed Urethane
Neck Shape Speed Neck with Rolled Fingerboard Edges
Neck Binding None - Rolled Fingerboard Edges
Scale Length 25.5" (64.77 cm)
Fingerboard Radius 12"-16" Compound Radius (304.8 mm to 406.4 mm)
Fingerboard Material Maple
Number of Frets 22
Fret Size Jumbo
Nut Material Floyd Rose® 1000 Series Locking
Nut Width 1.6875" (42.86 mm)
Position Inlays Black Dot
Side Dots Black
Truss Rod Nut Heel-Mount Truss Rod Adjustment Wheel
Truss Rod Wrench Yes
String Trees Floyd Rose® Retainer Bar
Headstock Licensed Fender® Stratocaster®
Neck Plate 4-Bolt Serialized
MISCELLANEOUS
Strings Nickel Plated Steel (.009-.042 Gauges)
Strap Buttons Standard
Case/Gig Bag Optional Charvel® Style 1/2 Economy Case (p/n 099-0612-100); Optional Charvel® Multi-Fit Gig Bag (p/n 299-1414-006)
