LOL 1
Wow! 0
I think the Tone Junkies captures are better than the Amalgam ones - of the ones I own anyway - they just sound more alive to me. They also do mad short term special offers so they can be a bargain.
https://kottracker.com/
It’s my favourite amp of all time and so far nothing has quite got it right, even with my favourite IR (G12-65)
So it’s going and the Nano is staying. To get the most from the Nano in my situation you need an external controller (as does the Tonex) I’ve used the Chocolate but have shifted to an MC6Pro. The ability to make captures in the unit has let me make a lot of caps of favourite Kemper and Tonex presets.
I have the Nano (and much prefer the editing to the Tonex I had before) and was hoping that it would be a compact all-in-one solution but you still need an external controller to be able to use the fx properly - you can use an expression pedal to turn on, say, an overdrive but it's more fiddly than simply stomping on a single switch, or you need a midi controller (board size is expanding again).
So I've added my HX Stomp back to my board (Nano in a loop of the Stomp).
Also, I'm not sure the Nano can be a useful multi-channel amp as there's quite a lag between switching presets.
Stomp controls the Tonex via Midi. Tonex doesn't seem to have any lag when switching between one of the 3 sounds in a bank.
Not tried it with a bank change as well as I never need more than 3 basic amp sounds.
The Stomp does most of the other FX although I've still not yet found any FX / modeller that does Fuzz sounds that react properly to the guitar volume so I have real fuzz pedals on the board too.
"You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
The Guitar Nerd
