Stratocaster Body with Gotoh 510 Tremolo, Ilitch Suhr Noise Cancelling Back Plate & more
Strat Body2-Piece Alder, 3-Tone Sunbursst
1.8kg
Contoured Heel with rear sculpted / chamfered lower horn
Comprehensively screened with graphite paint / copper foil
Gotoh 510T-FE1 Tremolo nickel finish with FST Block (stays in tune)
(Originally configured for a 6 screw trem, but modded by Max Cottam of Cottam Guitars)
Option 1 £260 delivered
Strat Body with Gotoh 510T-FE1 Tremolo nickel finish
Locking Tremolo Posts
Strap buttons
Jack plate
Option 2 (fully loaded - just add a neck) £340 delivered
As above plus
Pickguard with Tonerider Pure Vintage TRS1 Pickups
Oak Grigsby switch, CTS pots etc
Ilitch Electronics BPNCS Back Plate Noise Hum Cancelling System for Stratocaster
£260 delivered
The Ilitch BPNCS is a low impedance air coil built in a replacement backplate. It removes 50Hz hum while preserving single coil tone. Fender Stratocasters with 1, 2 or 3 Strat style single coil pickups can be retrofitted with BPNCS'
Open Tremolo Cut (OTC) Version so you can access the springs and claw screws if you wish, without removing the backplate.
Strength: VNT (Vintage) for AlNiCo Rod pickups with DCR 5.5kΩ - 6.5kΩ
Works with
- 3 strat pickups of identical wind and polarity (or)
- with a middle pickup that is RP/RW
I prefer the second (RP/RW); the Ilitch system is out of circuit in positions 2 and 4, where you retain that pure strat quack.
It does not eliminate inductive buzz - for that you'll need to screen your strat with Copper Foil / Graphite Paint.
The last 4 photographs show the system as (previously) installed on my strat.
One set of Nickel split post inline Strat / Tele Vintage tuners £15 delivered
Sperzel 3+3 tuners with Ivoroid buttons £43 delivered
These were on my old Collings 290 and seem to be of the non-locking variety. I
can’t test them since I don’t have suitable guitar - and so at a reduced price
New Unused HSS Strat pickguards (US hole pattern)
Black and cream £7 delivered each
Full back foil
3 String Swing hangers £12 delivered for all three
Miscellaneous Parts (Pic 1 and Pic 2)
postage at what it costs
(descriptions below the pics)
Pic 1
Tune-o-Matic Bridge & Tailpiece System Chrome £14(extra picture below)
3+3 tuners chrome £10
Selector switches
Two New Toggle switches £4 each
Used Patent pending 3-way £4
Used Patent pending 5-way £4
8 Chrome Amp Corners £10
VoodooLabs Power Supply mounting brackets £5
