I listen to a lot of heavy, loud drone and doom metal. A massive part of my playing is using feedback and dissonant sounds musically.
This is an example of the kind of thing I mean. I think this is really cool, but you may be unable to bear even the first song...
This kind of playing requires the guitar to react to the very loud amps as a big part of its sound, so I'm looking for ways to replicate this at home for practicing with. Turning up the drive and gain works a bit, but it makes it too unwieldy and hissy and then I need to re-adjust everything so I can play louder again.
There is the feedbacker effect which I was very excited about, but I don't think it works in a very natural way when used with in this kind of case. I could be wrong though, I might be using it incorrectly.
I'm pretty well experienced with the Helix now but this is something that's always eluded me. Thanks for any tips!
Peace, Love, Heaviness.
I reckon you could get part of the way there at lower volume by using a ridiculous amount of gain and a bit of selective eq, but there will be a threshold you have to cross depending on the cab, generally a 12 inch speaker would need a fair bit of volume to get there, but maybe you could try using a smaller one in parallel for the more squeally parts, maybe an AB/Y box to switch it in when needed.
I'm guessing you can also easily create patches with dramatically different amp / cab selections in Helix, so it should be simple to switch back and forth.
The actual feedback you want is really the relationship between pickup and speaker at volume, so there will have to be some compromises.
Try sending a signal to something like a Pignose and see what happens.
Edit: also there’s a that pedal show episode about using compression at low volumes to simulate the guitar/amp interplay you get at volume which might help.
edit I might have just invented a wah pedal
a new guitar wasn’t something I had in mind, this is really only for practicing at home. I can play the way I like in the rehearsals at volume totally fine, but learning how to control and use distortion in this way is something that needs practice and isn’t something many people have patience for when you need to work something out!
Doesn't need to be a new guitar.
