SORTED - Floyd Rose string blocks, ideally for a JT-6 Charvel/Jackson.
icu81b4icu81b4 Frets: 424
edited October 2025 in Parts £
I only need two, the ones already on the JT6 have a square flat top but I reckon the normal blocks will work just as well.
It’s for a Charvel model 6 guitar.
  • FunkfingersFunkfingers Frets: 16093
    I have a few JT-6 vibrato spares stashed away.
    NIT PICKING DETAIL QUESTION
    Are the square tops of your string blocks perfectly flat/smooth or do they have a slightly rippled texture?
  • icu81b4icu81b4 Frets: 424
    edited October 2025
    Hi @Funkfingers ;
    Thanks for the reply.
    They have a slightly rippled texture.
    I shall have a rummage through my parts containers and get back to you.
    @Funkfingers ;
    Panic over, another fellow of this parish sold me a couple..
    @Funkfingers ;
    I don’t suppose you happen to have the JE 1200 circuit board that fits a model 6 Charvel do you?
    Sadly, no.
    Are the stock pickups active or just the controls PCB?
    edited October 2025
    Hmm, the pickups don’t work without the battery so I’m assuming that means they are active.
    when I operate the pot that is soldered onto the pcb I get a loud buzz and the audio cuts out.
    although the guitar works when the pot is turned fully down.
     I reckon I need to take the pcb off and clean the pot and perhaps reheat the solder on the components to see if that cures it.
    The obvious clues would be the pickup's model number and a separate insulated wire to carry the power supply to the internal pickup.
    FWIIW, the functions of the Jackson midrange booster are not massively different from those of an EMG-SPC.
