Concerning stage volume for my upcoming gig...
Situation:
We'll have real acoustic drums, guitar amps, but DI bass and keys. All using in-ears for monitoring.
Venue is approx 200 cap including some seated at tables around the edge. The stage is pictured below - it's pretty big for the room.
I am definitely going to use my Fender Tonemaster Deluxe Reverb with pedals, and was considering adding a Matchless 20W Laurel Canyon for lower midrange and to allow stereo modulation (and because it'll look good for stage-dressing). TMDR will be halfway up the dial on wattage (probably max 1W mode) and LC will be with the MV quite low.
Following a noisy rehearsal in a small room where the in-ears weren't working some of the band is concerned I'll be too loud (noting that those concerned as those who don't have earplugs when not using in-ears). I think it'll be fine if I match the level of the drums and also there are a couple of points where I need a chunk of feedback, so need some volume to get there. I could barely hear myself over the drums last night and the amp was only on 2 vol (0.5W mode)
My gear is very intentionally selected so I'm not crazy loud but I haven't played a venue like this in years so want a sanity check... Thoughts please!
Vera & The Mixtapes - the newest, hottest, bestest cover band in the Middle East //
Instagram //
Youtube
Just make sure that you don't play first. Let the drummer stay playing them gradually turn up to join them. If you wait for people to get used to the drummer then you won't seem as loud.
If you set up first then immediately burst out the start of Eruption at gig volume then the shock will make them think you're too loud. Always let people get used to the drums first
Yep - this is my standard approach. I’ve specced that I need a riser on my side to get amp(s) to my own waist height (and over the heads of the crowd), and again the double amp is very much for spread, not volume
But I’m a big advocate of old school live sounds and wedges, because I’ve done it that way for decades. These days I get asked to go direct with IEM and listen to clicks/tracks/queues. The care for source is degraded to the possible benefit of the consistent overall audience experience.
But equally I've realised actually quite a big part of how I play guitar relies on a semi acoustic guitar and enough stage volume to get the air inside moving for a little bit of feedback. And that's incredibly difficult to acheive if there's no amp volume, clearly! In my originals band I used to run a little Laney VC15 which was not very loud, but have a bunch of it in the PA and a bunch of it in the wedge pointing right back at me. That was a fantastic little setup.
But further to the feedback thing, another part of it is we're trying to put on a show, not just stand there and play some songs. A rock & roll show should be loud and should have a bit of feedback and excitement - that's the whole point.
This is a really interesting topic that might warrant its own thread. I do wonder if part of why so many bands are so on-rails (and dull...) is because they're not actually listening to each other, but just the drums and their own part and some prerecorded cues or whatever. I heard an IEM mix on reddit the other day that was 90% drums & guitar and hardly any bass or vocals. I couldn't do it.
I note all the best musos I've played with have always just wanted something resembling the FOH mix with themselves a smidge louder because they need that to perform at their best - playing off the other players. IIRC Prince stipulated that everyone should have the same mix, including himself, because everyone's job included trying to make the overall mix sound perfect, which you can't do if you're all in your own little worlds
Without a sound engineer many bands can try to mix their own sound from their positions on the stage, which as we all know is not the ideal mix for the audience - it cannot be due to physics of audio. In this situation IEMs can be more a hindrance than a help as no one on the stage can even remotely guess the correct FOH mix. If you don't have a sound engineer at least take a trusted friend who can tell everyone on the stage what is working and what is not working from where the audience will be.
(I do want to hear a tonne of my own signal, but most importantly I want the mix to be right. A rock & roll mix that's right has quite a lot of guitar in it but not louder than the singing!)
Directionality has a lot to do with it as @Winny_Pooh says. Really they are designed to project for public address. Tilting them back or getting them to head height helps a lot combined with angling across
You can't really compare the SPLs of a rehearsal room vs a venue space so I wouldn't worry about it. A stereo rig will sound great out front with some stage bleed
All the bands I play for are loud, but that's ok as long as it's a solid musical loud. A good drummer is loud and it's fine because it's musical. A bad drummer playing loud just sounds like someone building a shed ...annoying!
Start the drummer playing a solid groove. Mix in the bass and guitars so that's all good and the PA isn't even switched on. Then add the vocals in the PA and all should sound fine with very little work needed from FOH
As it's early days for you and iEM's I would have a safety wedge setup. It can take a lot of gigs to get used to IEM's
I’ve said the same re backup wedges. I think it’s a good idea not least because while we’ve all now done a few rehearsals with IEMs some of us have never done a whole gig with them. And frankly also just because the system might go down in which case having a way to keep the show going is always a good thing
I assume your bringing in your own FOH, not using the speakers in the picture.
The last time I brought two amps, the engineer told me he preferred the tone of one over the other and just put that one in the FOH mix.
And as I say, it’s at least 33% about the visual…
