Bass cab mic ideas
What do people like on bass cabinets? And anyone using just a microphone for bass guitar? I know DI is the standard, so just wondering if anyone does it differently.
  • You could go full Geoff Emerick and turn a bass amp into a mic, Revolver style!
    I question the portability, but bet it sounds great yeah!
  • EV RE-20 or Shure SM7B
  • What do people like on bass cabinets? And anyone using just a microphone for bass guitar? I know DI is the standard, so just wondering if anyone does it differently.
    I have good results with a Sennheiser E906 but I've heard that an Audix D6 is good.
  • MartinBMartinB Frets: 465
    The last couple of times recording electric bass with my band, we took both a DI and mic signal, and just used an SM57, since the idea is that the DI fills in the low end depth, the mic is there to capture the interesting mids off the speaker.
    Aha, I have an e906, I might try that! Are you blending it with DI and using the mic for some mids as people are suggesting here?
    Yeah, I'm always keeping an eye out for a decent RE-20 price, good call.
  • PhilKingPhilKing Frets: 1768
    I use an AKG D112 on stage but have a Warm Audio WA-47jr that I use in my studio.
  • CirrusCirrus Frets: 8623
    Re20, fet-47, at40-series
  • Danny1969Danny1969 Frets: 13251
    The only mic we had in our collection at the studio that did a decent job on bass cabs was a Beta 52, so that got used a lot. I did a lot of bands that liked the Kyuss  / QOTSA bass sound and we used a couple of Ampeg bass cabs and that mic to get something close to that.
    I always took a DI as well which could be blended in or reamped back out in the live room.
  • octatonicoctatonic Frets: 35667
    Beyer M88 is my go to.
    RE20, SM7, Fet47 get used too.
    You can overthink this.
    Most things will be fine- and I mostly use the DI signal and just use the amp channel for some grit.
  • StuckfastStuckfast Frets: 2828
    My new year's resolution is to stop being lazy and record bass through an amp, not just DI. Might dig out some mics to compare and see what works.
    I've got sn M88 too, but it's my first choice kick mic, so it's usually busy (I mostly record things live). Maybe I need another kick mic instead...
    Earthworks DM6 is the absolute nuts on bass drum. I've stopped using my M88 there because the DM6 is just miles better.
  • Macca_25387Macca_25387 Frets: 107
    edited December 2025
    I’ve been using a Sennheiser Md421 with good results. About 8” back from the speaker.
    https://youtu.be/05_slliHCp8?si=MPzWKpyDpfJTmL7L
    This was the last result.
  • mike257mike257 Frets: 472
    Live, I tend to lean on a DI for the low end, and blend with a mic for a bit of grit and character from the amp. I'll usually use anything that would normally work well on a guitar amp.
    I see a lot of people using kick drum mics, but lots of them have a bit of an exaggerated sonic character to steer towards a punchy kick sound (Audix D6, I'm looking at you!) and I don't often want to emphasize the same areas in the bass guitar as they'll clash.  You'll still get plenty of useable low end out of the usual suspects you'd stick on a guitar cab if you do want to get it from the mic.
