Band currently use some proper cheapo units in the grounds it doesn't matter if they get trashed (Behringer 8500, Samsung Q7 etc.).
Tone is fine, but they do tend to pick up a lot of spill as heard on PFL, so I've been wondering about better options with shorter range/ better rejection, without going nuts. Obviously SM58 is standard due to robustness, but I'm not convinced the pickup pattern is hugely better. Would Sennheiser E835/E845 do a better job at not putting crap into the desk between songs? At least two of the singers can get right on the mic, so don't need a lot of air coverage.
Beta 58, E845 (not 835) are both that iirc. If you want to spend a little more the Beyer M88 TG is phenomenal but also quite nice and I don’t lend it to others!
Too much compression can exacerbate spill.
Bandcamp
Spotify, Apple et al
They're cardioid like the ones OP is already using, how do you find the spill into them?
