My dad has dabbled in playing guitar for decades, but he’s decided that for his 80th birthday (about a year away) he wants to learn a few pieces properly and perform them with yours truly.
To this end, he’s interested in recording himself playing. He’s never going to get into the weeds of plugins and studio-grade hardware - he just wants a simple, ideally free way to get his guitar into his PC and recorded.
He’ll need an audio interface, of course - I can handle that. But I do most of my recording in Reason and Logic, both of which are massive overkill (plus Logic is out as he’s on Win 11), so I don’t know what the best option to recommend software-wise is.
Reaper might be an option, but it would be too complex for his needs. Simple is better. Audacity maybe?
He’ll be recording himself on his Squier Strat, probably plugged directly into the interface with some kind of modelling plugin (which I’ll set up for him and ideally save as a template). I’ll likely use NAM if the software doesn’t have something built in. If it does, it’ll be fine. He also has an electro acoustic guitar which he’ll probably also plug straight in. It might sound like a bag of spanners but again it’ll be fine.
The only other requirement is that it would be good if he could play along to, and record himself with, backing tracks. I’ll be able to help him source the tracks (I might end up making them myself). I realise this is basic DAW stuff!
Dad’s a retired programmer and IT manager, so he’s technically minded, but I’m not sure how much patience he has these days for learning new stuff. The easier the better!
All ideas welcome.
I use Reaper, and would definitely recommend that over anything else, due to the way it can be configured to taste.
Do a bit of preparation for the default settings-ie where files are saved, backups etc, and then create a project that does exactly what you need, basic tracks, routing, layout, and then just use that as a template.
I used to like to open Audacity as a simple WAV editor, but now it seems to be trying to perform as a DAW, which means it is trying to do everything, via menus.
No real problem with that, if you are willing to learn how it works, but with Reaper, the template you open is already set up as basic ( or as complex ) as you want it.
As your Dad gets comfortable with the concept, it can grow with him-rather than having to menu dive to do stuff.
Reaper also works across platforms, and is very easy on the resources.
No brainer really.
https://www.thefretboard.co.uk/discussion/288885/
This has been an interesting thread!
