Wiring diagram help
Hi there, please can someone point me to a diagram for: 4 conductor HH, 1 vol, 1 tone. 1-bridge, 2-inner slugs, 3-both, 4-don’t care, 5-neck. Thanks!
  • Dave_McDave_Mc Frets: 2702
    edited May 14
    (I'm assuming that's right, I've never had the guts to mess with superswitches!)
  • longshinslongshins Frets: 292
    I don’t want a superswitch ideally as I’m poor and have a few decent 5 way ones.
  • ICBMICBM Frets: 83547
    You can’t do it with a standard 5-way.
    The closest you can get is -
    Neck
    Neck + split bridge
    Both
    Bridge + split neck
    Bridge
    The two split positions will sound more like what you want than you might think - the split pickup will dominate the mix because it’s lower impedance.
    Thanks for that. Could you point me to a wiring diagram please? I know the colour coding of the pickup wires.
  • FunkfingersFunkfingers Frets: 16187
    I have messed. I recommend this well-known DiMarzio/Ibanez circuit.
    https://www.dimarzio.com/media/1447
    Bridge
    Inside (slug) coils
    Bridge + neck
    Neck (coils in parallel)
    Neck (coils in series)
    Master volume, master tone, nothing else.
    If a CRL or Schaller 24-contact switch seems too pricey, consider the 2502N PCB type. It does the DiMarzio/Ibanez circuit but, by definition, it less robust.
    edited May 16
    It’s the same as the standard Telecaster scheme, with the pickups connected to the switch rotors and the volume control to four terminals - because a standard Strat 5-way is identical to a Tele 3-way, but with extra notches for the 2 and 4 positions - then connect the coil splits to the unused terminals.
    1 2 3 4
     5 6 7 8
    (1 at the neck end of the switch)
    1 - neck hot
    2 - neck split
    3, 4, 5 and 6 - volume pot
    7 - bridge split
    8 - bridge hot
    If the wrong coils are selected in the 2 and 4 positions, reverse the hot and ground wires on both pickups.
    Bridge
    Inside (slug) coils
    Bridge + neck
    Not sure how I missed that one, I think I just stopped when I found one which matched @longshins ;' requirements!
    That could be useful if you had a hotter neck pickup, I could see parallel working well in that case.
    Thanks everyone!  I’ve found that pcb switch on AxesRus and have had a few Ibanez HH guitars over the years and love this setup. I just need to match the colour codes of my Tonerider pickups to the Dimarzio scheme then I’m good to go!
