Neck pocket and neck heel question
I've seen a tele neck on ebay which i really like...also seen a nice surf green vintage modified squier jag that i really like too.
Together, it would look really cool...but...will it fit?
I had a look on fender website but didnt see any measurements of the pocket size...but from the seller of the neck i got measurements. The width is 55.5mm and depth is 90mm. He also said that the heel has been rounded slightly.
Can anyone let me know if this is going to be a fit, or am i going to need to do some woodwork to get it to match?
Also...jag trem bridges...how are they with downtune...like a b or c standard...any issues??
  • WezVWezV Frets: 16754
    Tele necks onto strat pockets does need a little bit of woodwork. One is square on the end, the other is rounded
  • ICBMICBM Frets: 72563
    If you use heavy enough strings, they work as normal. Fender used a standard one on the original Bass VI which is essentially a baritone Jaguar.
    cool thanks for the answers...
