Has anyone ever tied this....
therose789therose789 Frets: 467
I have just bought a RV5 which has two stereo ins and outs
Has anyone ever tried wiring it up like this
Guitar into Input 1 then out of output 1 back into input 2 and then out of output 2 into an amp
Does this just make the effect twice as loud or does it do anything at all?
Will i die if this happens?
Answers on a postcard please
  • Never cross streams or the universe will explode. Or something.
  • ICBMICBM Frets: 72687
    You'll end up inside the reverb with the normal world on the outside.
    It depends how the 'stereo' is done. If it's true stereo you'll just get double the amount of reverb; if it's pseudo-stereo it may feed back on itself, but that won't actually do any harm although it may whistle or do other strange things. Could be quite cool really!
  • I will try it and send you my findings!
  • Turns out you dont go into the future you just get a LOT of reverb and then a load of feedback!
    Seen people do this with DD7's - it can sound pretty cool if you put a volume pedal in line with the second signal, and use it to swell the feedback in and out!
  • I was thinking about using a switcher so i can change if i want TONNES of reverb or just a bit using the same technique
