sold FS/FT Boss RC50 Looper
£250 as new, light home studio use
RC-50 Loop Station
The ultimate looper with 7 footswitches
3 stereo tracks with multiple overdubs can be handled simultaneously (i.e. in parallel like a 3-track DAW)
as much as 49 minutes can be sampled before the memory is full.
There is USB out for backup to PC and stereo, mini jack or phantom powered XLR inputs. Microphone input
Specifications
AD Conversion: 24 bit
DA Conversion: 24 bit
Sampling Frequency: 44.1kHz
Program Memories: 99
Nominal Input Level: INST -10 dBu, MIC: -50 dBu, AUX: -16 dBu
Input Impedance INST: 1 MOhm, MIC: 1 kOhm, AUX: 100 kOhm
Nominal Output Level MAIN OUTPUT: -10 dBu, SUB OUTPUT: -10 dBu
Output Impedance MAIN OUTPUT: 2 kOhm, SUB OUTPUT: 2 kOhm, PHONES: 47Ohm
Available Recording Time: STEREO: Approx. 24 minutes, MONO: Approx. 49 minutes
Display: 16 characters, 2 lines (backlit LCD), 2 characters, 7 segment LED
Power Supply DC 9 V: Supply AC adaptor (Roland ACI or ACB series)
Current Draw 450 mA
Dimensions: 472mm(W) x 198mm(D) x 64mm(H), (18 5/8" x 7 13/16" x 2 9/16")
Weight: 2.9kg (6lbs, 7oz)
original box, PSU etc
