Anyone on here gone Kemper?
ragingbenragingben Frets: 107
edited August 2013 in Digital & Modelling
Has anyone on here gone Kemper? If so, how are you finding it, and are you gigging or mainly recording/playing at home. Also are you using FRFR or power amp and cab?
I'm considering having a purge of some amps and other gear to fund a un-powered head, and then get used to it at home for a few months before deciding to go FRFR or power amp and cab while I save up for that section hopefully ready for gigging. Which brings me to the next point, anyone got one of the newer power heads? If so, reckon it is worth saving the extra for, or just using that money to get an FRFR solution?
As much as the hype is surrounding the KPA I don't expect it to sound 'just like a tube amp' I just want something flexible, decent sounding and something that will put the GAS to bed once and for all (yeah right!).
«13
    Have used one several times. Bought one and had it a day before I decided ultimately that it wasn't for me. Incredible tones from it though, and way easier to use than the Axe-FX (imho)
  • ragingbenragingben Frets: 107
    Interesting... If you don't mind me asking, what was it you didn't like about it? There is a lot of postivie/negative feedback about the Kemper but a lot of the negative seems to be nit-picking and a lot of the positive seems to be fan boys harping on about their new toy!
    I'm thinking of keeping my main gigging rig but having the Kemper as a bit of a all in one solution for home use, recording and maybe gigging if I can get used to not having a proper amp/FRFR.
    There wasn't anything I didn't like about it. But it's £1300 odd, and having it sat on my desk whilst also having a £1300 Satriani JVM next to it... just felt a bit over the top! It was one or the other, and I was not prepared to sell my JVM in order to fully go Kemper.
    So the Kemper wouldn't have been used all that much, and would've just sat there. So I sent it back. Still kinda want one, but can't entirely justify having it.
    Ah I see. Very lucky man having those options mind! The £1300 is the downside to the Kemper obviously... when do the premium bonds get drawn, about time I came up!
  • Jim54Jim54 Frets: 244
    I've had my Kemper for nearly a year so I'm way past the honeymoon period.
    I've since sold a couple of my tube amps and my AER 60 acoustic amp.  My remaining tube amps have not been switched on in over 6 months (Hand-wired JTM45, ToneKing Meteor II combo and a Mesa Lonestar Special).  I now only play at home and record though, so take from that what you will.
    I play it both through FRFR (cheaper side - Alto TS112A) and via a Matrix GT1000FX and a 2X12 Matamp cab.  Enjoy both (sometimes at the same time).
    Piece of piss to use and the tones are fantastic (forget yourself for 2 hours fantastic).
    A lot of peopler using them seem to be on the heavy side of tones (really high gain stuff) but for me who lives in the gritty clean to overdriven zone, then the Kemper really shines.
    I took a punt on one and love it.  I'd highly recommend one but maybe take advantage of a 'so many day' money back guarantee like with Thomann and try one out for a few days.
  • rockmonsterrockmonster Frets: 838
    edited August 2013
    Anyone heard a Kemper being used in a live gig/pub situation? Whaddya think? I haven't heard an Axe-fx either! :-\"
    Thanks @Jim54 that's good to know. I've started sorting some bits for a sale at some point to help raise funds although it is going to be a little while before I'm anywhere near Kemper-ready!
    Everyone seems to be getting the Kemper-loose-track-of-time moments. It seems that people love them just for being able to turn it on and not have to tweak - just straight into the playing with inspiring sounds which sounds grade a to me. I used to have the time to tweak and I loved that but I just don't anymore with one thing and another. I want my playing time to be about playing not tweaking.
    Good advice on the 30 day money back guarantee though, I think I will definitely go with that.
    I might have to pick another one up and try it into a cab. That was the only thing I never tried when I had one a few weeks back, and I'm kicking myself for not doing it.
    The other concern I have is about patch changing and how instantaneous it is - I can't actually remember!! Plus I think performance mode is still in progress.
  • I wouldnt bother Drew.  I tried one for a while (thinking it might be a cheaper option to my AFX), and its week point is into a cab.  Its just not designed to work that way - with most profiles having the cab part baked in to the profile.  With no way for the usit to know what cab was used in that profile, its a generic "subtraction" to make the profile work with a real cab.
    Its not "bad" and there are usable sounds - and of course you can profile without a cab (from a load box for instance), and there are such profiles out there - but there arnt that many really.
    A/Bing between the Kemper and AFX - there both great.  The Kemper is more plug and play and works best into a FRFR system with some pretty good bread and butter FX in fixed routings.  If thats what you want then the Kemper probably has the edge.  For flexibility of routing, FX quality/type/edit-ability, and for using with a real amp/cab the AFX was just a lot better.  I also felt the "live" functionality of the AFX with any Midi controller (not just the MFC) was much better - however, the Kemper may have moved on since I tried it in that respect.
    Im not going down the "amp" tone as such - there slightly different but both great.  Neither are perfect compared to real amps, both are very close.  IMO the Kemper had the edge when released, but the AFX has taken the crown back since around Firmware 8 (now on 11).  The AFX development moves much quicker than the Kemper (which is both a + and a - of course).  I find the Kemper sounds to be a touch too sharp/raw BUT thats personal, as is all tone and it doesnt mean the Kemper isnt better for others.
    So - basically, if you wernt convinced with the Kemper into an FRFR system you wont like it into a real cab.
    You may be right Paul. There is a guy on Youtube called FastRedPonyCar who has done it though and had some fantastic sounds. If I'm in Andertons at any point I might give it a bash in one of their small rooms, see how it stacks up.
    Christophe Kemper said recently that they've been working out a better way to disable the cabs, so once that lands it'll even out again I guess.
    When I tried Jim's Axe-FX rig I was convinced. I think he has Celestion golds in his cab.
  • He certanly has one - but I think hes got 2.
    My cab is a V30/G21H mix and I love it.  It does limit the power handling to 60w, but Ive not run out of "volume" yet.  If I do Ill upgrade the G12h to a CL80 doubling the cabs handling - or possibly invest in a Matrix 2x12 as they are using neos in a ported cab, and the cab is extremely light and by all accounts sounds great.
    This is the video I was referring to. Some absolutely killer tones in there.
  • Si_Si_ Frets: 384
    They really do sound good in a studio environment.. not sure how they would be live..
  • Anyone heard a Kemper being used in a live gig/pub situation? Whaddya think? I haven't heard an Axe-fx either! :-\"
    I was down Railside Records, Salisbury, demoing the AF2 today.  We had the balanced O/Ps into the desk, panned hard.  It delivered the goods.
  • I had one, sold it as I wasn't using it much, and am now planning to get another. There's a profile of a Morgan AC20 on there which just blew me away like an amp has never blown me away before - it sounded to me just like Guitarist's recent review of the actual amp.  And I'm sure there will be more like that given some time to explore it.
    Still not decided on powered + cab v FRFR - probably the latter though I want something small and light...
  • Si_Si_ Frets: 384
    I've got a Matrix Q12 for my AxeFX II, still trying to get a good sound out of it but getting there. Not tried it live yet but hoping it will give me a tiny live rig :)
  • DeijavooDeijavoo Frets: 3298
    Pardon my Noobness, what is FRFR?
    Full Range Flat Response.
    Studio monitor or PA type speaker drivers essentially. They don't (or aren't supposed to) colour your tone like a guitar speaker does.
    Ah, cheers.
  • crunchmancrunchman Frets: 11451
    I heard one last year although it was a slightly bigger gig than your usual pub.  The sound out front was a lot better with the Kemper than it was when I saw the same band the year before and the guitarist had a Marshall half-stack.
    I borrowed one for a weekend a couple of months ago.  I was impressed with the sounds in it.  It's much better at that edge of breakup stuff than any other "modeller" I've used.  Didn't try doing any of my own profiles though.  Definitely want to get one at some point.  Need to sell some things first though.
