Help with modded esquire wiring
Basically I want to use a 3 way switch
bridge position = volume and tone pot with 223k cap
middle postion = volume and cocked wah tone eldred mod?
neck position = killswitch/off
the closest diagrams ive found are below, what changes do i need to make as the switches look different,
  • GuitarMonkeyGuitarMonkey Frets: 1883
    Use the first diagram which has everything you need, just in a different order.
    Reorder the switch positions by swapping the orange and Eldred cap wires at the switch.
  • ab2014ab2014 Frets: 89
    Thank you I was getting for myself confused on the switch layout
