Hardening burl/spalt wood?
I just want some experiences from guitar builders who have hardened burl or spalt.
I have a nice buckeye burl book-matched top, and it's a bit soft, so I would like to harden it before building.
So has anyone used thin superglue? Or shellac? Or any of the rotten wood hardeners?
I want to spray nitro lacquer over it so I guess some of the hardeners might not react well to nitro either?
Anyway, anyone done it successfully?
  • octatonicoctatonic Frets: 33851
    What is its providence?
    Has it been properly seasoned?
  • SerratusSerratus Frets: 121
    Yes, it's properly dried, etc, it's just quite light and soft compared to most hardwoods you would use on a guitar.
  • WezVWezV Frets: 16810
    I have used spalt a fair few times now and have used a few bits that had patches that were practically spongey.   I used a lot of thin superglue, horrible process and I am not totally convinced it penetrates all the way through
    having just repaired an old window with some rot hardener last week I would be tempted to give it a bath in that stuff neck time.   you will still need to think about filling any voids, good quality epoxy and some dye works well for that
    lots of cellulose or shellac sealer before any nitro top coats touch it and it will be fine
    I know someone else who uses superglue so that seems like the most common method.
    He also mentioned that he tried a rot hardener but found that it left a sticky residue that was a nightmare to get rid of, so I don't really want to try that unless someone else has tried a specific product successfully.
    Seems like superglue is the most likely thing to use. And I have plenty for cellulose sanding sealer so I'll just hit it with lots of that before lacquering (thanks for the advice Wez).
  • boogiemanboogieman Frets: 12448
    Calling @timmyo. Pretty sure he used the superglue treatment on a spalted maple top.
  • TimmyOTimmyO Frets: 7583
    edited August 2015
    Yes I stabilised a very soft/flakey spalted maple body using superglue.
    I found that you can buy it in big pots (rather than lots of 5ml tubes :-) ) and that when you buy it like that there are different thicknesses - I think I went for medium or thin rather than the thickest on offer (apologies I don't seem to have any bookmarks from back then)
    It worked extremely well and the resulting finish stood up to my hamfisted sanding perfectly well.
    There are a couple of pics on the blog I did : http://100poundguitar.blogspot.co.uk/
    Red ones are better.
  • JadenJaden Frets: 251
    I have used thin superglue and also used it with that special powder that mixes with it to fill large cavities or voids.
    Jaden Rose Guitars :: Jaden Rose Guitars on Facebook :: My Facebook :: YouTube
    The young do not know enough to be prudent, therefore they attempt the impossible - and achieve it, generation after generation.
