SOLD: Line6 DT 25 Head / cab
RevMattRevMatt Frets: 839
edited October 2015 in Amps £
  • RevMattRevMatt Frets: 839
     I was a bit sparse on the info above so here's a bit more:
    This is a fabulous amp that covers every possible tonal need. 2 channels, each with 4 switchable voices, it can go from crystal clean to the highest of gain settings. Line 6 designed front end with the power stage designed by amp guru Reinhold Bogner - this is a proper pro amp with a more traditional design than Line6's modelling gear.
    25 watts (of valve power) will kick out enough to gig with, but one of the amp's many switchable options is the ability to switch down to 10 watts to retain all that valve power tone at lower volumes.
    It also has a ton of interfacing options so can be linked to other Line6 gear to make it even more versatile and controllable.
    This is a really stylish, functional, and high quality piece of kit in fantastic, near mint condition.
