Noisy Dunlop wah
CatthanCatthan Frets: 367
Hey guys,
my dunlop wah has is hissing a bit when it's disengaged,, I think this started a few days ago, just troubleshooted the board and it is the culprit.
Bought for cheap on the bay..
As it is my first wah I was wondering if it is smth common and whether there's an easy fix etc..
Please post if you got any ideas..
Thanks,
T
  • FezFez Frets: 537
    First up try a new battery
    Don't touch that dial.
  • ICBMICBM Frets: 72767
    edited November 2013
    If it's not that, it sounds like the input buffer might be leaking noise into the bypass path - the pedal is 'half-arsed bypass' and so the circuit input is connected to the signal path even when it's switched off.
    You could try replacing the input transistor, or - to kill two birds with one stone - convert the pedal to true bypass.
  • CatthanCatthan Frets: 367
    I though it would be smth like that, just couldn't put the words behind it... No battery.. Will try and sort out the circuit..
