FS AMT SS-11A Preamp
John_AJohn_A Frets: 3776
edited March 2016 in Amps £
AS new, boxed £165 posted, amazing sounding and very versatile just not getting any use as I've moved back to big amps
Looks just like thisimage
AMT Electronics SS-11A Classic Guitar Preamp Features:
  • Fully tube-based 4 - stage overdrive channel with DUAL TUBE design (2x12AH7 tubes) with high-voltage anode voltage (+300 V).
  • Three separate channels: CLEAN / OVERDRIVE / LEAD - Individual gain sensitivity and output level controls for clean and crunch/lead channels.
  • TREBLE SHIFT toggle switch to enter bright mode for that added punch of high end.
  • FX LOOP for external effects.
  • OUTPUT jack for connecting to both specialized guitar amplifiers with a standard level of 0 dB (GUITAR AMP mode) and a CAB SIM MIXER out with a standard level of -10dB and a guitar cabinet simulation.
  • The preamp outputs are equipped with sophisticated solid-state buffers.
  • SS-11 incorporates new field-effect transistor-based guitar cabinet impulse response emulator processing. Improved naturalness of sound when connected to line input.
  • Special attention was paid to transistors anode power quality: preamp uses a specially designed high-voltage transformer minimizing the penetration of impulse noises into amplified signal.
