New Peavey Micro Head - a good back-up solution?
not_the_djnot_the_dj Frets: 7306
haven't seen these mentioned here yet...
https://peavey.com/news/index.cfm/id/841/Peavey Unveils the.html
20 watts micro head, could be a nice small back-up alternative.
    ...seems to be around £175.
  • ecc83ecc83 Frets: 1647
    Hmm..? 20 watts into 16 Ohms, wonder how they get around the theoretical 80W into 4 Ohms?
    Very saggy PSU? Current feedback?
    Dave.
  • Tuscan777Tuscan777 Frets: 125
    Orange Micro Terror competitor.....if a fair few more spondoolicks
  • FortheloveofguitarFortheloveofguitar Frets: 4292
    edited July 2016
    Thomann now showing available from sept at £158
  • John_PJohn_P Frets: 2754
    Looks interesting but I suspect it will be hard to get a useable clean sound - a handy back or home amp if you only need distorted sounds though.
  • digitalscreamdigitalscream Frets: 27018
    Dave.
    And, given that most 2x12" cabs are 8 ohm, it'd present a bit of a problem if anybody tries to use it that way.
    <space for hire>
  • ICBMICBM Frets: 72922
    The spec given there is wrong - it's 20W into 4 ohm.
    https://assets.peavey.com/images/large/118865_34384.jpg
    It would be pretty stupid to build a solid-state amp that needed a 16-ohm load.
    I just hope it doesn't use the same power module as the Micro Terror - which I think is a proprietary bought-in unit, rather than something Orange designed.
  • octatonicoctatonic Frets: 33896
    Lack of channel switching is annoying but otherwise it could be a decent emergency backup if it doesn't sound too shit.
