Pedal friendly amps
professorbenprofessorben Frets: 5105
Ok so we hear the above term used quite a bit.
But does it only relate to drive/gain pedals?
Have you ever found a phaser that doesn't work with an amp?
or a delay that kills in one rig but sucks in another?
  • JezWyndJezWynd Frets: 6149
    I found that my Phasers (DOD 201 and Boss PH-1) didn't work well with an Excelsior amp, could hardly hear the effect. Using a Laney Cub 10 into the same 15" speaker and they worked fine. Haven't got a clue why that would be.
  • professorbenprofessorben Frets: 5105
    Interesting. That's exactly what I mean.
  • GrunfeldGrunfeld Frets: 4065
    There are amps, and there are pedals.
    Some amps are friendly with some pedals.
    Some amps are friendly with some other pedals.
    This is how I own so many other other pedals.
  • ToneControlToneControl Frets: 12065
    pedal friendly amp?
    that would be one that's clean enough to not kill the pedal, I would have thought
    Matchless DC30 cleanish
    Dumble clone , Mayer-style, cleanish
    some twins and I assume Deluxe reverbs
    Hiwatt
    I find my Sound City 50+ sounds great with pedals at bedroom volumes
    Yes but which pedals do you find cause the most awkward combinations?
    pedal friendly amp?
    Hiwatt
    Yes but if o took that to the 'nth degree then a flat PA would be the best pedal platform?
    to my mind the natural compression and tone of the pre amp causes all that lovely drive and complexity, BUT. Is that not compromising elsewhere with modulation and time based fx?
    What about when you turn the wick up?
    A.clean/PA-Style amp will reproduce the new exact sound of your pedal(s). Some pedals do not appear to work/like other pedals (ie some don't like buffered pedals before/after, etc
    Yes but the exact sound of the pedals is rarely desirable in drive/gain tones, it's the shaping of the pre amp that gives the nice tones, but what about what it's doing to the other pedals in the chain
  • p90foolp90fool Frets: 31834
    pedal friendly amp?
    I find these two to be very picky about drive pedals in particular, almost an electric guitar plugged into a hifi type of sound.
  • thomasross20thomasross20 Frets: 4438
    I'm not saying just because I consider(ed) getting one, but everybody seems to say the Victory V40 takes pedals really well?
    I find no amps respond well to chorus pedals.
    Have you guessed I hate chorus?
    Ha ha, me too, but I think it's the player not the amp, I'm less hating on the chorus if I put it into the front, it's a bit less 'hi-fi' and sweet.
    Exactly what I'm talking about, people say it takes pedals well, but what pedals?
    i have an Avid 11r which has models of all the usual suspects ( Rat,TS,Muff etc)
    and I find I much prefer the Rat and Muff models to the real thing.
    its rare anyone says " yeah tried a BassBreaker the other day, sounded great with my CarbonCopy but sucked with the DD7"
    its almost always drive pedals people refer to when describing how 'friendly' an amp is to pedals.
    I think complex time-based FX sound pretty crappy with dirtier amps
    you know, Big sky, etc
    Best on an FX loop  I guess for those FX
    I think all the FX loops I've tried damaged the tone , even when using a Kleinulator, but I am  more inclined to use a boutique amp with no pedals than most people
    some ODs need a dirtier amp to round off their  spikiness
    I think you'd need to subdivide types of pedal before saying which amps  work well:
    e.g. an ultra clean Low-power  Tweed twin will take  all delay FX, compressors and mellow OD well, but not  a  fuzz box (I assume)
    This.
    its something that piqued my curiosity after reading something on Gilmourish.com
    Bjorn ( the guy running it and excellent guitarist with prog rock outfit Airbag) mentioned that F style amps give a less pronounced sound to Phaser/Flanger/Chorus as the lower mids give less emphasis on the sweep, but M style Amps are more extreme in the effects, he also mentioned that delay repeats often get in the way less on F style over M style again due to the mids.......
