GONE: H&K Puretone Head
photekphotek Frets: 1469
edited March 2017 in Amps £
Only on the block as I want an amp that is for sale on here, if that goes before this does then I will be keeping it.
The Puretone is a monster, loud, proud and direct. Marshally, Voxy and even Fendery depending on where you set the growl control. More headroom than pretty much anything I have owned and I use it regularly with a loud band unmic'd without needing to turn in up past 9 o'clock on the volume.
Most people think these are 25w amps but when using it woth an 8ohm cab they are actually rated at 40w and I would say that is a conservative figure.
Recently revalved and I will include a spare set of matched, working EL34's.
You are welcome to come and test it out if you are in the Cambs area.
£600
Pics in a bit!
