Elac BS244 Bookshelf Loudspeakers (Passive) £650
Hi, I'm selling my Elac BS 244 bookshelf speakers
and Atacama stands.
The Elacs are great sounding speakers. The only reason I am selling is because I have upgraded to the floor standers from the same range. I am the second owner - the first owner had them in a second system and then traded them back to the original dealer as part of a p/x.
Very good condition, there's a tiny scratch on one of the sides that I was not able to photograph. There's a couple of scratches on the bottoms, again very small. Comes with dust covers, bass port bungs, dispersion control rings. They are in the original box with original packaging so I can post these no problem.
They have a very flat frequency response so can be used for monitoring. The tweeters are quite famous for their detail and accuracy.
height x width x depth 330 × 200 × 282 mm
weight 7,4 kg
type 2-way, bassreflex
woofer 1 × 180 mm AS-XR cone
tweeter 1 × JET III
crossover frequency 2,600 Hz
frequency range (IEC 268-5) 38 ... 50,000 Hz
sensitivity 88 dB / 2.83 V / m
suitable for amplifiers 4 ... 8 Ω
recommended amplifier power 30 - 200 W / channel
nominal/peak power handling 80 / 120 W
nominal impedance 4 Ω
minimum impedance 3.5 Ω / 190 Hz
Also got a pair of Atacama Nexus 6i stands in silver with gel pads and atabites filler, £50 collect from East London only.
More photos
