Pickers - what picks are you using?
I usually use a JD nylon .60 for acoustic stuff by default...but as I've experimented a bit on electric and found 2 very different favourites there, I guess I should do the same for acoustic. Plus, even though I've been using these for years, I don't really like them :)
So, acoustic pickers and strummers of tFB, what are your favourite picking devices?
  • LewyLewy Frets: 4291
    I use a real mixture but mostly gravitate towards Wegen Bluegrass picks and one of these from Charmed Life:
    http://www.charmedlifepicks.com/product-page/fbb08a19-ab87-d6e2-0bba-3119c233246a
    If I'm looking for a really clear and crisp sound then Dunlop Ultex 2.0mm work well too.
    I've tried Red Bear - just sounded scratchy to me. Blue Chips too - they sound and feel amazing but I haven't found a shape of theirs that I get on with.
  • Ultex .94 (James Hetfield), Tortex green 0.88, and currently experimenting with Tortex yellow 0.73. This is for playing lead lines rather than strumming.
    I like the attack of Ultex, it sounds like celluloid but lasts a bit longer.
  • Dunlop Nylons, .60 or the Max Grip if I want stiffer. Tortex .50 for bright strumming tones. .73 or .88 nylons for lead.
  • Dunlop 0.88mm Nylons for everything - unless I'm using my fingers.
    They're light enough for rhythm playing and stiff enough for lead parts. I like their tone - not as 'sharp' sounding as other materials - and blend well with fingers when hybrid picking.
  • @Lewy those are some big picks - is that normal in the Bluegrass world?
    edited November 2016
    Very normal, yep. Thick picks, medium strings, dreadnought guitars is the typical set up.
    The bluegrass rhythm/strumming technique is quite specific and enables you to play quickly and lightly with a thick pick and then dig in for accents/bass notes with a lot of power using rest strokes. It's not a typical strumming approach (i.e. hitting all 6 strings, wide arc of movement) which would be better served with more flexible picks maybe.
  • Interesting, thanks!
    Fingernails.
    Or claws as they're sometimes described.
  • Wegen Bluegrass as mentioned. They sound so much better than any off the shelf pick that even drummers hear the difference.
  • JD Nylons .60 .88 - Martin & Co .96 - JD Big Stubby 3.00mm or JD Thumb pick depending on what style I'm playing, but mostly it's just nails and side of thumb.
  • mgawmgaw Frets: 5302
    moustache picks 3mm or 4mm   or blue chip
  • I tried a 1.0 ultex today and actually it sounded pretty good with the Lowden.
  • stratman3142stratman3142 Frets: 2214
    Jazz 3 Ultex 1.38mm for acoustic, electric and bass when I use a pick.
    It's not a competition.
  • Great thread as I have two thin-medium plectrums only and need more!
  • Jim Dunlop USA Nylon .6, .73 or .88 depending on mood. I used to exclusively use the 1mm, but find myself stroking rather than stabbing these days. Even on bass.
    That's reassuring for everyone that lives near you.
  • Dunlop Gator grip 2.00 for me ...
  • mellowsunmellowsun Frets: 2422
    I got one of the brand new picks from Wolfram (not the metal ones), it's one of the only thick picks that doesn't sound dull and thuddy, down to the way the bevel is made and polished.
  • axisusaxisus Frets: 28348
    Can't do plecs with acoustic. Finger strumming and fingerpicking for me.
  • Winny_PoohWinny_Pooh Frets: 7835
    It's not all about you.
