New guitar, need some help
paulhpaulh Frets: 0
HI,
Starting to get a bit better at this guitar playing lark now so I'm going to treat myself to a shiny new axe to replace my cheapo ageing Ibanez. the one I'm looking at has a floyd rose type locking trem. Never touched one before so is there anything I need to know about tuning, changing strings etc? I'm assuming you get it about right with the pegs, lock the nut then fine tune with the screws on the bridge? Do these things stay in tune well enough?
Cheers!
  • GrunfeldGrunfeld Frets: 4042
    Well, I was a bit dubious about floating trems, only ever had hard tails, and then went so far as to block off the trems on my first three Ibanez RGs.
    On the 4th RG I decided to try it.... not a problem as it turns out.
    Basically, so long as I change one string at a time, stretch each string in nicely, then every thing is fine.  And they do stay in tune.
  • monquixotemonquixote Frets: 17656
    Try before you buy as they are a bit of an acquired taste.
    Essentially you get a bit more bother when changing strings in return for it never going out of tune.
    I personally don't bother with them as I find both the PRS trem and the Bladerunner on my Strat never go out of tune when set up properly.
  • There is a bit of debate over locking vibrato quality.
    Basically, some ibanez ones are known to not last long or develop problems. They don't seem too consistent, though, but look into the specific models.
    I've used an original Floyd rose (Korean, rather than a cheaper licensed one) and it's made in the same way as the 'proper' Floyd rose ones, but in the East. Very nice it was, kept tune great (mik bc rich gunslinger, if you wanna look for one). My mate has a guitar fitted with a gotoh one, and it's just as good and works perfectly. Has done for several years now.
    Some cheaper ones are made from pot metal and seem easy to break, basically. Try before you buy, as with everything guitar related.
  • When changing strings (more than one at a time) I find a pack of playing cards is really handy to keep the tremolo in place,
  • mike_lmike_l Frets: 5700
    http://www.thefretboard.co.uk/discussion/219/floyd-restringing-adjusting#latest
    Follow directions until you're happy, or give us a shout if you get stuck.
    Just remember not to over (or under) tighten the screws..
  • paulhpaulh Frets: 0
    Brillliant, cheers!
    Just remember the screws literally need nipping up, you're clamping a guitar string not attaching an axle to a truck.
    Ask me how I know.........
    There's a pissabolity I've over tightened and broken saddles before..........
    :-S
