Had a proper Spinal Tap moment at Friday night's gig...
FarleyUKFarleyUK Frets: 2422
Playing a birthday gig for my drummer's 50th, and I use a Relay G70 wireless unit. Never had any issues before - but this time, for whatever reason, I keep getting taxi radio interference!
Got to the point where it was really really obvious as well, and a channel scan didn't correct it. Very annoying; I just hope that, in return, they got an earful of cranked Les Paul on their end.
Anyone ever encountered this before?
  • richhrichh Frets: 453
    If your system is operating on the old channel 69 / 70 then you may have more and more of this problem, as frequency allocations have changed.  In short: older systems are likely to be less reliable and more prone to interference.  If you got it recently maybe worth checking with whoever you got it from.
  • FarleyUKFarleyUK Frets: 2422
    You mean the receiver's channel? The G70 only goes up to about 16 I think from memory. Got the system about a year and a half ago.
    You shouldn't get radio interference on a digital wireless unit
    The only time I've seen that happen is via an Induction loop (for hearing aids) which hadn't been switched off
    In that case, I have no idea what was causing it. I was running from the G70 into the Line 6 Helix, and then out to a QSC K10 powered speaker.
    My guess possibly a lead problem and the venue being near the taxi transmitter
    www.maltingsaudio.co.uk
  • Had it years ago on a radio mic receiver. We were sat down having a quiet few minutes before going on and a Taxi that was outside came over the PA at tremendous volume.
    Learned to mute the PA that day.
