FS: Soundcraft Spirit Folio SX Mixer for sale £180 ono
This great mixer is for sale for £180 ono. It
has served me perfectly for about 5 years. And is in great working order.
Really compact and can handle up to 20 instruments. I've used it for my 6
piece band (including brass) but it can also be used for the following:
Live situations:
Bands, Small Venues, Schools, Conference, Houses
of Worship
And studio Recording:
Digital/Analogue Multitracking (4/8 track),
Small/Home Studios, Pre- and Post-Production Submixing. Location Sound
Here's what Soundcraft say about this mixer:
Spirit SX is a flexible 4-bus mixer capable of
producing Digital sound quality for both live and recording applications. It
includes 20 inputs as standard and 18 outputs (including Auxs and Direct
Outs). In addition to mix outs, two sub-buses allow groups of instruments to
be sent to multitrack, to additional speakers, or sub-grouped to mix. There
are also four stereo inputs for keyboards or other stereo instruments. SX's 8
Direct Outs are fader pre/post switchable so they are equally useful for
recording in the studio or at a gig.
12 mic/line inputs are equipped with
Soundcraft's UltraMic™ preamp giving a full 60dB or gain range and +22dBu of
headroom, meaning that the SX input stage can handle any mic or line device.
In the EQ section, the classic British 3-band EQ with swept mid benefits for
custom designed pots which give greater control across carefully chosen
frequencies. There are 2 auxiliary sends, 2 of which can be assigned pre- or
post-fader making them equally useful for monitor-heavy live mixes or
effects-heavy recording. In addition, there is a separate Mono Output and 2
subgroup outputs.
100mm faders are used through giving more
accurate control at mixdown and all pots have been custom designed to give
even and consistent response around the entire sweep. The SX fits all of
these features into a rugged, compact frame with integral carry handle which
can be optionally rack-mounted in to a 10U space.
Key Features:
18 outputs including aux and direct outputs
12 mono channels with high quality UltraMic™
pre-amps
4 stereo inputs
4-bus architecture, with sub-group routable to
mix
Direct outputs can be switched globally pre- or
post-fade
Inserts on all mono channels
3-bands 'British' EQ with swept mid-band
Stereo 18dB/octave 100Hz high-pass filter to cut
stage rumble
+48V phantom power
Channel On switch for mute control
Two sub-group outputs
Separate mono sum output
Impedance balanced outputs
Rugged aluminium chassis with integral carry
handle
