Anyone wired up a Fishman 9 pin jack?
I'm planning to use one of these on my guitar build
Anyone wired one up before? I basically want to wire the following to it: a Sustainiac pickup, a trem piezo and standard pickups.
  • ICBMICBM Frets: 72922
    The two vertical contacts in the middle are the tip and ring - the one closest to the camera should be the tip, but check - and the other six are two isolated SPDT switches - the middle contact is the common, the one closest to the tip/ring terminal is the normally-closed and the outer one is the normally-open. (The big terminal at the far end is the ground obviously.)
    So you could use the two switches to turn on the power to the Sustainiac and the Fishman, and still have the magnetics and piezos on separate outputs.
  • axisusaxisus Frets: 28353
    Thanks @ICBM I er ... got some of that! It's a long way to go before I get to wiring, but I thought I'd get the groundwork going early and start drawing up a plan. Much to figure out with this guitar ....
