What do you use your BB preamp for?
DefaultMDefaultM Frets: 7372
Just recently got one of these, been using it with my Hotrod Deluxe and its not as high gain as I expected. However, its also incredibly loud and seems to do a pretty good boost with just a bit of gGain. Is that what people mainly use theirs for?
On my board I've got the thorpyfx peacekeeper, gunshot, muffroom cloud and warthog; which seems excessive.
At the minute the BB seems most similar to the peacekeeper when I was expecting to be comparing it to the Gunshot. My original plan was to have the peacekeeper and BB on the board but I'm unsure now.
  • DefaultMDefaultM Frets: 7372
    Tried it against the thorpy pedals in a range of settings and it doesn't really do anything new or better, so it's on ebay.
  • I find the BB to be the most versatile overdrive I've came across. It goes through phases being used as boost or a crunch. Im sure theThorpy pedals are great also but I think the BB is a real classic
  • gibsongretschfangibsongretschfan Frets: 1050
    edited February 2017
    The BB Plus is a real stinker
  • The slight compression on the BB is very pleasing on a Strat neck pickup.
    I'm just using it with a HRD. Is it better with a Marshall type amp?
  • rawk100rawk100 Frets: 1757
    Using my bb as a boost to tighten my Marshall up for teh bro0otalz. Treble and volume at 12 o'clock, gain at 9 o'clock and bass at 10 o'clock. Doesn't cut the bass like a  toobscreamer yet still tightens things up, has a nice lower-mid thump.
    Works with both, with a fender amp it sounds a bit like a souped up tubescreamer and with a el34 type amp it gets quite claptony
    This is pretty much why I prefer the axe fx. I'm so used to having a really saturated sound at a low volume level that when I plug in to my amp and pedals at the same volume I'm always taken back that I can't get a smooth sound.
  • TimmyOTimmyO Frets: 7544
    I used to use my BB MB version as an instant silky-lead-sound - but that version probably had more mids
    As someone else above says, avoid the BB+ version like the plague, it is terrible, and the BB circuit is on NEITHER side of the pedal
    Red ones are better.
