PS Elements or Lightroom
d8md8m Frets: 2434
edited February 2017 in Off Topic
Linked with my new laptop purchase I would like to start taking more photos, I've got a decent camera(d3100) and could do with a bit of software for editing.
Narrowed it down to either PSE or Lightroom. Which one is better suited for amateurs?
  • RaymondLinRaymondLin Frets: 11900
    One is for photo manipulation (PS), one is for processing (LR).
    LR is also a catalogue program.
    They work in tandem with each other but start with LR, I process tens and thousands of photos a year and they all go into LR first, and perhaps 1% will go into PS for more advance stuff.
  • What he said. Unless you already know you need more, you probably need LR. It's great :)
  • d8md8m Frets: 2434
    Can I use lightroom without the catalogue feature?
    Ive always managed my photos myself in Windows explorer folders as I find it makes it easier to back up/recover
  • wibblewibble Frets: 1110
    You can get Photoshop CC and Lightroom CC for £8.57/month on the creative cloud photography plan
    https://creative.adobe.com/plans?store_code=gb
    I'd rather buy outright not a fan of subscriptions :)
    Not really, because it would defeat the point. But LR works almost exactly like windows explorer in terms of how it looks at folders - it shows you exactly the folder structure that's on your drive. But if you move things around outside of LR it won't know where you've put them unless you tell it. The learning curve it literally 5 minutes and SO worth it.
    It would be pointless doing that because you don't "save" the photo, the point of LR is it never touches the photo, instead if remembers the processing steps you do and saves the steps.  When you export a photo it creates a copy of it.  The original, the RAW file, the negative, is never touched.
    Like you do with film, you can process the negative for print, no matter how many print you make, the negative stays the same.
    Also, you can go back every step, no matter how many or how old.
    Ah ok that doesn't sound to bad, LR sounds better suited for what I need than PSE.
    how is it on file space?
    Depends how big and how many photos you have.
    The "catalogue" size grows with your photo collection.  You can always save and back it up.
    LR might have to wait till next month, double the price of PSE :(
    That's about to go up to £10.10 a month to new users
    Just in case you haven't figured out, Adobe software is pretty much all susbcription now. PSE is still available as an outright purchase though. Lightroom 6 was the last version of Lightroom you can buy outright. While it's still supported for bug fixes, new features will only appear in Lightroom CC.
  • boogiemanboogieman Frets: 12397
    My 2p worth is to get Corel Paintshop Pro, it's only £45 from Amazon. Does a lot of what PS will do and is more than powerful enough for amateur photographers. I've used it for years and always found it gives great results and it's easy to use.
  • Everything they've said about Lightroom. It's the go-to.
    I only use photoshop for the occasional shot where I reckon brushing in a Google nik plugin is a good thing, or for retouching (it's far quicker to retouch in photoshop than Lightroom because it works at pixel level). But that's really rare - two photos out of 400 required that for me so far. And they didn't need it... I just like to use it to convince myself I'm not being royally screwed with subscription plan, which will go up in price soon...
    The only other thing photoshop is great for is enlargement. I print at 20x30" or 30x45" sometimes (or equivalent in cropped ratios) which is massive. Photoshop has a clever tool to resize, resharpen and noise reduce when enlarging.
  • hywelghywelg Frets: 4303
    Aftershot Pro is worth a look too.
    This sucks.
    I always like to buy software outright, even it costs more upfront.
    Been looking into both and PSE might actually be better for my needs as it gives me a bit of both worlds.
    This looks interesting, Ive used CorelDraw with work before but not PSP.
  • VaiaiVaiai Frets: 530
    I used to work with Photoshop professionally and had it and LR at home nfor my own photography but unless I am doing something semi pro I just use Google's Picasa which is free and does basic touch up and PP. If you decide you really expect to spend more time doing photography then LR is great. And as above - almost all Adobe stuff is subs now.
    Thats how I found out about Aftershot. I use CorelDraw a lot, have for 24 years.
    Affinity Photo seems to be getting a lot of traction as a PS alternative...
    https://affinity.serif.com/en-gb/photo/
    £48.99
