pearloid inlays on ebony fretboard
What glue to stick them in? Superglue OK?
Also, what's best to fill in the gaps? they are very small.
  • WezVWezV Frets: 16768
    Superglue.  The pack the voids with ebony dust and add a drop of superglue
  • axisusaxisus Frets: 28341
    So you pack the dust in first then use superglue - you don't 'mix' them first?
    You won't be able to mix them first, the superglue will set as soon as it touches the wood dust.
    Superglue has great capillary action, so a drop or two applied to a pile of dust will soak right through and set very quickly... on some woods you even get a bit of smoke as it cures.  You do need a thinner glue for this, won't work with the gel types.  I actually find cheap superglue best if you can't find the water thin stuff locally.   Wilko's basics is halfway between a standard superglue and an expensive bottle of water thin stuff.
    One thing to be aware of it the fill can polish up shinier than the wood. If it was a big fill I would suggest decent epoxy and ebony dust instead, but the superglue trick is fine for most small fills, especially on ebony
    Many thanks! I'll give it a shot.
