Anyone on here gone Kemper?
  • ragingbenragingben Frets: 107
    Thanks for all the info guys. If I was to ask the question again I would go with "who has had a Kemper and gone back to a regular amp and pedals". There seems to be those that can handle it sounding and feeling 95% or whatever and those who really want the last 5%
  • hywelghywelg Frets: 4303
    I'd ask a slightly different question.
    For those who have a 'good' valve amp does the Kemper feel the same and do the amp profiles (either those that come with it or those that can be downloaded) feel and sound like an amp should when playing clean. I think, though I might be wrong, that modelling is better able to fake an amp with loads of distortion than a clean amp just on the edge of distortion.
    And how much of a compromise is it to put the Kemper through the output section and cab of a valve amp? What puts me off is all the extra gear it is suggested you need in order to get acceptable results, midi controllers, FRFR amps and cabs etc. If I thought I would get good results through the output section of my Dumble clone and 2x12 I might be more inclined to give it a go.
  • ROOGROOG Frets: 557
    I have noticed a few people have Kempers in this place, and I wondered how they worked through headphones? I'm guessing that in theory they pass as FRFR.
    I just wondered if the Kemper came across as harsh or fatiguing through headphones?
    If I had one, I'd end up using it like this for quite a bit.
  • PVO_DavePVO_Dave Frets: 2375
    Headphones are fine :)
    I use KRK headphones to keep the response nice and flat still, no harshness etc..
  • GassageGassage Frets: 30887
    Sorry, headphones! Simulators? What about burning glass and bleeding eardrums?!?!?!?
    Thanks @PVO_Dave that's encouraging.
  • ThePrettyDamnedThePrettyDamned Frets: 7484
    edited September 2014
    Funny, as a high gain player I think the opposite.
    Clean sounds are usually pretty responsive to me - different tones from the pick attack.
    High gain is where modellers let me down (never tried axe FX or kemper or the one Andy James used for a while).
    Then again, I heard a demo of a strat through a dumble on tgp people were wetting themselves over and to me it was a very boring, plain tone. Maybe different types of players "get" different things.
    Edit: Here is said tone.  I really don't get the fascination - it's pleasant but it really isn't amazing, especially on the hard strums where it's plain unpleasant.
    Again, maybe different styles of players "get" different things.  I find modelled high gain tones are a bit fizzy, and lack 'chunk' compared to valve amps.  However, modelling is pretty good these days - the blackstar ID and ID Core are phenomenal for the money, and I've no doubt the AF2, Kemper and DV Mark Multiamp are much nicer.
  • Whilst I probably do sound like a fan boy harping on about my new toy I stand by what I've said before on here.
    Live the Kemper is the dogs bollox - sounds superb when properly EQ-d up gig volume.
    Only negative I can think of when using it through the PA is that I can't fookin hear myself so have to use a monitor.
  • This thing about 'feeling' like an amp or not; I've now done two gigs with the Kemper direct into the PA. When I play with my band I can never actually hear my amp that well over the drums and bass so invariably have it coming back through the monitors at me.
    That is the sound you expect to hear from the Kemper. So to me it sounds jsut as good as the amp I normally hear through my monitors except I don't have to bring 'my amp'. The sound guy also finds it easier to mix and I have 100's of amps to choose from and have fun with - cushtee!
  • John_AJohn_A Frets: 3775
    'Feeling the amp' really depends on what you are used to, 'back in the day' I switched from using two 100W Marshall heads and 4 4x12 cabs to a JMP-1 and a 1x12 monitor, it obviously felt different.  If your normal amp is a princeton reverb set at 2 and mic'd up it's not going to feel that different at all
    Nothing to stop you using a Kemper through a power amp and 4x12 for your on stage sound and direct to FOH for the audience if you play venues big enough
    It s fucking ugly, my mother had a teasmaid that looked like that...
    Why don't you go and flambe your own cock?
  • For my money the biggest draw with the Kemper is the ability to access a massive range of sounds and effects, it helps if you suss out what to ignore or not use and the range of options is daunting to figure out at first, I have found in a lot of cases less is definitely more but again once you suss it out it's easy, the ability to programme the unit and foot controller (You need one of these !!) to be able to switch profiles/sounds for different songs / parts is useful, it makes doing the river dance on the effects board a thing of the past, one button does the lot if you get it right
    Be choosy with the profiles that you use and pick ones from credible sources, and use ones that make you sit up from the off it's like recipes some of them are just plain shit and don't work well, another issue I have found is the old "polishing a turd" scenario, if you start with a bad profile, you're gonna struggle trying to adjust it into something you want. I spent weeks trying to do this and eventually deleted everything in the unit and started again, the rig manager software is essential for efficient management of profiles you can try them and tweak them if you like before you load them which is a good option, I now have less than 30 profiles in total in the unit, and that's maybe too many if I'm honest.
    Once you find the right profiles and get your head around the Global output and amp EQ's there should really be no issue with playing live through a cab, if you run a line out to the desk the cab can be basically a stage monitor anyway and you have different settings available for the line to the desk and the cab outputs anyway so you can tweak what you like. I use both a JCM 900 4 x 12 and a Jet City 2 x 12 with mine depending on circumstances and yes you need to tweak the Kemper to account for the differences but it's no great issue.
    Previously I have been using Marshall and Blackstar valve amps for a number of years , I still own a JCM900 Twin Reverb 100w head, which never gets used I hasten to add, and some of the profiles I have for more unusual / classic amps, Plexi's, AC30's, Matchless DC 30, Selmer 50, Hiwats, JTM's and the like are awesome, and some of the others too, Diezel, Engl, EVH 5150, Soldano and Mesa Twin Rectifier are amongst my favourites.
    Lastly I would say due to the costs involved it takes some thought before you buy, it took me the best part of 3 or 4 months to get my head around using the Kemper, and I'm not there yet, so having one for a week or so probably won't unlock the box enough but that's only speaking from my experience, I'm no gear officionado, and I'm not pretending that I have the greatest sound in the world but I sure have a whole bunch of options available in one little box that I never had before and all this is just my point of view for anyone that's interested
    Cheers, Chris
    Will do when your girlfriends finished with it, then I'm gonna form a Russian Circles tribute band.
    I don't have a girlfriend B-)
  • NerineNerine Frets: 2110
    Kemper.
    GREAT in the studio. I mean, absolutely unrivalled. Massively flexible, easy to use, easy to capture amps, sounds bang on, does what it says on the tin. Etc etc etc. absolutely LOVE mine as a studio tool. Saves me having to run amps flat out at work every day.
    Ever band is always totally blown away by how they can't tell the difference between their micd amp and the Kemper.
    Live. Mixed feelings. Good to a good PA. Not sure about using one through a guitar cab. Direct profiles are probably much more usable in this scenario now though.
  • Had mine for two years now haven't used anything else since ....loved it so much that when I sold the amp I did have ....I used the money to buy a second one (from here :)
    Great in the studio obviously but use it 3-4 times a week every week for gigs ...switching between Acoustic,Electric,Bass,Mandolin,Banjo and even Sitar Guitar now ....straight into PA sounds great ...no heavy cabs to lift etc ...can't see me changing unless the Kemper 2 arrives :)
    Nerine said:
    Kemper.
    I don't know about live, but I personally struggled to get it sounding close to my VHT Sig X. I don't know why, but I sent Christophe some audio clips, and he swore down that they were exactly the same. To me there were massive differences. I could get it fairly close to my Diezel, but not the VHT. Weird.
    I sold my Kemper to get the Helix, because live use was more important for me and the Kemper wasn't flexible or quick enough at switching patches for me. But now I'm not getting the Helix.
  • richhrichh Frets: 450
    I've got the Kemper Remote, and I can't hear any delay when switching patches, not sure what it is like with other footswitches, like the Behringer.  As regards sound quality, that is a personal thing, and may depend to some extent on what you're monitoring it through.  Lots of other options though, such as Helix, AxeFx or real valve amps...
    edited October 2015
    Yeah, with the remote in performance mode there isn't any noticeable delay, I know this is something they really focused on. There's also now an adjustable X fade between rigs if you want to do that but personally I don't see much point. Live it's a mixed bag, I've had much better luck with the newer merged profiles and a decent cab in a more traditional set up rather than through a PA and monitors, I haven't tried a FRFR cab though. At the moment I'm using PRS Archon profiles from Origin Audio, no idea what the actual head sounds like through the same cab, but it's by far the most happy I've ever been with a rig, just really thick and meaty.
