Feline Guitars - customer builds updates
  • FelineGuitarsFelineGuitars Frets: 11590
    edited August 2017 tFB Trader
    A guitar being made for a banjo player who wanted something that would feel familiar that he could play open G bluegrass, blues and Rolling stones open G guitar licks on
    Open G tuning makes Keith Richards licks a must
    Yes the inlays on the front of the narrow necked beauty are laid out like a bluegrass instrument - 10th inlay instead of 9th
    We had a special 5 string hardtail bridge made just for this guitar
    Oil City pickups made us some special 5 polepiece pickups with coil taps to go between a tele sound to a more P90-ish sound. These will have custom cut flatwork inside an open fronted humbucker shell.
    We adapted a 6 string headstock - brought the two tuners on the underside in a bit and visually separated them with a small pearl heart. There will be a Feline logo on there too when it's all finished
    All access neck joint ....why not
  • Wow - That's awesome. Presumably the body is a little smaller than a normal LP?
    Body is standard size and scale is 25.5" - so it'll feel not too strange for him compared to his Banjo
    Now got some lovely pickups from @TheGuitarWeasel for the Banjo guitar
    Specially made 5 string "big block" pickups by Oil City Pickups .
    These have a tapped winding to allow you to switch from a Telecaster type voicing and a P90-ish voicing
  • earwighoneyearwighoney Frets: 3494
    Lovely work. A very interesting project and great solution to it.
    Would it be possible to ask who made the custom bridge?
    edited April 2017 tFB Trader
    The bridge was made by an engineer friend of mine who does a few bit and pieces for me when needed
    Wasn't cheap in the end but was a tidy way to do it
    Thanks for the info Jon.  The bridge looks very tasteful and looks perfectly at home.
    Lovely work again.
  • KebabkidKebabkid Frets: 3305
    edited May 2017
    @FelineGuitars - I was over at Jonathan's today and he's putting together and putting out some great pieces. That 5-string in G tuning was wonderful.
    The workmanship, weights, playability and resonance of these things are superb and whilst I really like the Lions, those Lion Cubs are pretty special.
    Great guy, great guitars and good company, too. Nice chatting and catching up, Jonathan and cheers for sorting out my pedalboard.
    Just finished another of our Tabby Hybrid models.
    This melds together classic elements of strat and tele designs with our own twist.
    A swamp ash body mated to a three piece maple neck with a separate fingerboard.
    We alter the body shape to utilise a stray style lower horn so a regular start pick guard can be used
    Rear view showing the all access neck joint and the start style contours on the rear
    Electrics are a trio of Bare Knuckle Irish Tour pickups and an LR Baggs piezo equipped strap tremolo bridge
    We used Luminlay  side marker dots that glow for an hour from a 5minute UV charge
    The lean back headstock  with a volute  and locking tuners
    An Earvana Compensated Tuning nut helps with giving the guitar a greater degree of in tune-ness
  • TimmyOTimmyO Frets: 7411
    Nice. The tilt-back and outline of the headstock is very Hamer (which is a good thing!)
    Red ones are better.
    That blended body shape is fab too - great looking guitar
    So Mathieu's Lion Supreme finally got assembled after paint took an age to get her done.
    Lightly quilted top. Lightweight build and a slim neck with a 42mm wide nut - like on his G&L
    The back was done in satin finish whilst the front was all glossy
    Still got that comfy heel
    Seymour Duncan Tripleshot mounting rings allowing each pickup to be set for series humbucker, parallel humbucker and each of the two single coils chosen on it's own.
    Pickups shown here are a pair of Oil City Masterwound Tubesnake model which were designed to give a vintage PAF with an alnico 2 magnet. The tone benchmark players were Slash and Billy Gibbons ...hence the Tubesnake name.
  • Wowzers ... that thing is amazing. The neck joint is something to behold!
  • breadfanbreadfan Frets: 379
    @FelineGuitars ;Is this an oil finish? It looks incredible!
    No - it's satin polyurethane finish on the back, with a gloss Poly finish on the front
    Well the Russ Ballard inspired guitar we built got to meet the original recently, and got played by Russ Ballard too
  • JerkMoansJerkMoans Frets: 8792
    Turing weight relief into a design feature.  Cool.
    Inactivist Lefty Lawyer
  • DrBobDrBob Frets: 3005
    I meant to ask when i saw this on Facebook earlier, was there any reason he went for a Tele neck on it ? Even more weight reduction from the smaller headstock ? Maybe thought the square heel would mean less side to side movement now that there is less side support from the neck pocket maybe ?
    Or just needed a new neck and that's what was available ?
    Russ Ballard's guitar wasn't drilled out for weight reduction as far as I know  - it was pure;y a looks thing .
    The 70s ash bodied strat body that I made into a Ballard inspired guitar on the other hand DID need weight reduction as it was killer heavy. It was like a boat anchor. It was a left over body after we made the owner of the original guitar a new lighter body for the original
    Russ' strat neck had a hole drilled in the headstock too and this made it split when it was dropped on tour some time in the 1970s. They found him a neck to replace the broken one and it happened to be a tele one. There wasn't anything more cunning than that , although it may be that he liked the feel of the neck.
    Been neglecting posting my updates for a while . Here is one for one of our FretBoard brothers
    A Feline Lion Supreme with a touch of a '59 LP look about it
    Still got the easy neck access players love
    Added a couple of push /pull pots subsequently to give phase reversal and coil split tone options
