Kemp Guitars *2017-2018* Build Thread
xKempGuitarsxKempGuitars Frets: 182
edited February 2019 in Made in the UK
My first (2016) build thread was looking a little tatty so I've decided to start a new thread - which coincides nicely with the start of some new builds that will show a new direction for Kemp Guitars.
I won't give too much away now but all will become apparent as these two stock builds get underway.
Kemp Guitars - Custom Made Guitars for the Modern Rock & Metal Guitarist
0reaction image LOL 1reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
«1345678
  • xKempGuitarsxKempGuitars Frets: 182
    edited January 2019
    Some crude mock-ups for the next two builds - both will have Sapele bodies, Wenge/Dark Birch (inverted) necks, Wenge fretboards, 25.5"-26.5" multiscale/half-fanned, Gotoh hardware and EMG 81 pups. Finish will be matte PU.
    edited January 2019
     Fanned fret DC and SS underway... Looking a bit dull at the moment
  • TTonyTTony Frets: 17510
    That Dark Birch looks interesting.
    During the Covid19 period, we're running a "phone a friend" facility.  Just to hear a voice, keep in touch, etc. , using "JitSi".
    There's a Jitsi iOS/Android App, or you can connect from a browser.
    https://meet.jit.si/theFretBoard  |    pw: theFB  |    0121 468 3154  (pin 2491 5627 21#)   |  10:00 and 20:00 daily.
    edited January 2019
    Something different to use. It's got an odd colour, bronze-like, but when it's wiped over with spirits or water it turns a deep orange-red colour. The smell when machining it is fantastic too - smells sweet, like sugary coffee or syrup.
    It looks like it could be Black Walnut (grain, etc) and it's about the same hardness/density and weight, but I would only use it laminated until I knew more about it. I've not come across it before, and it's not an easy one to get hold of over here. There's a couple of small pieces on eBay and barely anything about the stuff in general on Google. This'll probably be a one-off.
    edited January 2019
    Further progress on the latest DC and SS (formerly referred to as the "Dinky-style") builds. The bodies are now ready for finish/fine sanding...
    0reaction image LOL 3reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
    edited January 2019
    Nearly forgot; going back to those SS colour mock-ups I recently posted. I had decided to go with the yellow, but whilst messing around with the images I came up with this orange which I'm quite drawn towards. Thoughts - yellow or orange?
  • webrthomsonwebrthomson Frets: 559
    Something like this appeal to anyone? These are rough mock-ups for the next two builds - one Dinky style archtop (colour undecided) and the Kiwi Green DC. Both will be Sapele bodies, Wenge/Dark Birch (inverted) necks, Wenge fretboards, 25.5"-26.5" multiscale/half-fanned, Gotoh hardware and EMG 81 pups. Finish will be matte PU.
    I like the green meanie - how much adjustment does the fan fret take - I've seen but never played one?
  • OilCityPickupsOilCityPickups Frets: 5053
    Slanted pickups for fan fret instruments, in this case 14% slant 7 string 'Masterwound' Blackbirds designed by us for Carillion Guitars ...
    Formerly TheGuitarWeasel ... Oil City Pickups  ... Oil City Blog
    0reaction image LOL 2reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
  • WezVWezV Frets: 9472
    I have always preferred to go with normal pickups, i think of it as being like the bridge slant on a strat.   although its worth noting that the kemp ones above has a fan starting from the bridge so a single straight pickup looks fine.    I have always had the fan starting from somewhere between 12th fret and nut which obviously gives more slant on the bridge end
    Nice to see my Masterwound  Havoc in there again Wez ... always thought it really suited the look of that guitar.
    it sounds bloody awesome in it too.
    I love this sort of stripped out look ...
    [PIC REMOVED]
    Hello Sir - that's my favourite at the moment too. Sealed both builds today so I should be shooting primer before the weekend and top coats next week
    The fanned frets, despite appearance, don't take long to get adjusted to, even with the bigger scale length differences, such as 25.5"-28", and full fan (neutral fret around 7th to 9th, or even 12th fret). I decided to adopt the "half fan" because I feel it offers the same benefits but looks less daunting and, therefore, might encourage more players to try out multiscale... I can also fit any standard bridge, unlike full fan builds that have very limited options.
    Do you do other angles? I've used BKPs (limited to 12 degree) and I've had Lundgren make me an M8 with a 25 degree angle. But if I the need came for angled pups then I'd like someone UK based that can make them for me
    [PIC REMOVED]
    Nice build. I think it works looks-wise (non-angled pup)
    Nice build. I think it works looks-wise (non-angled pup) =)
    The Havoc pickup was designed for guitars like this, it's a balls to the wall metal pickup with triple magnets and a 16k DCR, but with over height bobbins, so it retains all the high end harmonics and splits to be like a true single coil ... like two 8k strat pickups in the same unit. Sorry ... I'm very into what I do :-)
    No, that's good to know. I did consider Oil City pups on a recent(ish) build. I will have to find out more and perhaps try out some of your products - including the Havoc by the sounds of it. It's getting late and I need some sleep so I'll take a look through your site tomorrow and start thinking about pups for my next stock build. Initial thoughts were something along the lines of the SD Distortion... Or maybe I'll just try out The Havoc =)
    I put a push/pull in the volume control too.  The split sound is one of the best I have had, and I have tried a lot.  I was really happy when Ash said he could do a double white one too.
    Oh, and apologies for posting one of mine in your thread.  I thought it showed a slightly different approach to a similar style of guitar.
    i sometimes have people say they have tried fanned frets and it wasn't for them... but often they don't remember what scale lengths it used of where the fan started from.  There probably is a fan that would work for them.
    No, I'm glad you did. Like you said, it's a different approach and works with both the full fan and, what I like to call the half fan that I'm doing. Thanks Wez
    I also develop pickups specifically for and with builders as I did with Blackmachine. I can always cut you a deal m'boy ;-)
    [PIC REMOVED]
    I'll tell you what, I'd like to get the current stock builds finished and out the workshop asap as I'm going to be moving house (and workshop) sometime over the next two months. Once I'm all set up at the new place then I'll get in touch with you directly and we can have a chat - That also gives me time to think about what I'd like to be putting in my builds as standard
    By all means ... phone me anytime you like ... my number is on the Oil City website :-)
    Thanks, will do
    edited January 2019
    Sealed and primed - the new DC and SS Archtop builds looking good in white but they're still getting those colours
    edited January 2019
     These colours 3
  • axisusaxisus Frets: 14974
    I don't actually buy guitars any more, I just make my own, but I have to say that these are looking really good! Very nice indeed. I look forward to seeing the finished articles.
    Thanks axisus, I'm looking forward to seeing them finished too - I haven't really had the chance to use colours like this before and the whole style/spec is my own taste. It will be hard to see these go :/
    I have built one guitar, and I know from that that I could never build guitars and sell them.
    edited January 2019
    Finished these two...
    0reaction image LOL 5reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
  • ^ New post
