Bad Cat Cub iii 15
smudge_ladsmudge_lad Frets: 653
hey Guys,
So following on from my recent post about Vox amps, @Wazmeister kindly put me onto the scent of a Bad Cat Cub iii that’s for sale on here. I didn’t really consider it at first, but now I am really tempted by it.
My only concern is that with it being only a 15 watt amp, will there be enough headroom in it for playing live. I would mostly be running the amp on edge of breakup/crunchy but still need that wee bit extra volume for some solo’s etc.
What’s are people’s thoughts on using them in gig situations?
Am I right in thinking @StuartMac290 uses one? I also seen some posts from @miserneil but that might be a 30 watt beastie?
I’d love to hear all/any feedback anyone has with this so I can hopefully make a decision
Cheers in advance
Keir
«13
  • IvisonGuitarsIvisonGuitars Frets: 6838
    @smudge_lad I do have the 30w Blackcat but have had a 15w version too, BadCat are notoriously conservative with their volume ratings, 15w will be fine for live, its just a little more 'spongy' that the 30w. But they excel at the edge of breakup/crunch thing IMO :)
    http://www.ivisonguitars.com
    (formerly miserneil)
    I'm not sure what venues you are going to be playing, but if the audience is big enough, you are going to want to mic the amp anyway, in that case, you are basically using the amp as a monitor. Vox type amps also tend to be quite loud relative to their power ratings so I think it should be ok.
  • DominicDominic Frets: 16015
    They are a bloody loud amp like the Matchless that they are based on
    You will probably find that you never get it past 6
  • stickyfiddlestickyfiddle Frets: 26754
    It's an amazing amp. It's probably the loudest 15W I've ever had, and a nice big cab so it sounds "big", for want of a better word. That's assuming you don't want clean-clean like a Twin or something, not least because it's at its best at that chime point between clean & definitely-not-clean.
    That said, I'd want to mic it up to better control on-stage and FOH volumes far before it go to the point it wasn't loud enough for FOH
  • WazmeisterWazmeister Frets: 9450
    Bad Cat/ Matchless have that unique, wonderful ‘best of Fender/best of Vox’ kinda sound, imho
  • pmgpmg Frets: 298
    I haven’t played a cub but only have good things to say about the black cats and classic deluxe models
  • smudge_ladsmudge_lad Frets: 653
    I’ll be playing venue’s ranging from small pubs (50 people?) to mini festivals of up to 500 folk. 9 time’s out of 10 i’ll be mic’d up, but occasionally I’ll either have no monitor so will need to turn the amp up, or I won’t be mic’d up at all.
    I guess I could always stick an EQ pedal in the FX loop I suppose, to boost the mid’s and maybe a wee bit of volume for any solo’s?
    I used my 15 watt Laney at practise last night to try and get an idea of volume with a drummer etc, but it’s only got a wee 10” speaker so it didn’t really blow me away. It still had some volume available, but I’m guessing the bigger cab/speaker in the Cub would handle things a lot better. The amp in general is probably miles better too I’d imagine
  • BluesyDaveBluesyDave Frets: 410
    I had a Classic Cat for a while.  Great tones at home and studio but if you're playing with a drummer......hmmmmm.  No.  Not if you want any clean headroom at all.
    No Darling....I've had that ages.
  • pmgpmg Frets: 298
    Classic cat is based on a tweed deluxe isn’t it?  So clean headroom -or lack of wouldn’t be a surprise
    I think so.  It was 2  6V6 for sure.
  • BroccoBrocco Frets: 88
    I have a 15w Matchless and can confirm it is loud, however I don't gig. Calling @slacker for his perspective.
  • richardhomerrichardhomer Frets: 24793
    I used to own a Cub IIR about 15 years ago.
    For ‘edge of break-up’ it was very loud - and sounded epic. For ‘true’ cleans - it had very little headroom - certainly nowhere near loud enough for live use.
    Still an amp I wish I’d kept....
  • algroves1algroves1 Frets: 17
    I had a 15 watt Black Cat combo that I traded for a 30 watt Cub III head (purely because I wanted a head rather than a combo).  I've only ever used them in my studio, but I'd agree with the above that they are loud for the wattage, but more importantly have tonnes of depth, sound huge and really fill a room.
    I would say that neither amp really has much clean headroom, once you get the speaker moving they are chiming and starting to break up.
  • StuartMac290StuartMac290 Frets: 1428
    edited June 2018
    Sorry, Keir, I'm late to respond here!
    I do indeed have an early Black Cat 30 (not 15) and it's probably my favourite amp. It IS loud though, to the extent I only use it in the studio - being an early model, the master volume isn't very good at all.
    I did have a Cub III 30 combo too, which was much more useable live because of the K Master. Actually, my favourite of the more recent Bad Cats I've tried was the Black Cat 30 just before they started fitting the K Master, if you can find one of them.
    Slightly controversial opinion here perhaps, but I personally strongly prefer the 30 watt models. Even in half power mode they sound bigger and more 3D to me.
    For edge of breakup tones I think they're unbeatable, and actually with my old one the cleans are unbeatable too. I've never quite been able to get a newer one to sound like that, particularly the EF86 channel.
  • svejksvejk Frets: 148
    Just to give you a below the radar option have you come across bluebird amps? E.g. https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/142503118654.
    I have no link except that I own one! An 18w handwired bestie with an ef86 channel and el84s. Sounds like it might be ballpark the same kind of thing. Easily giggable (I barely have to turn it up even for garage rock gigs) but not massive super clean headroom of course. I think the build quality is great though I can't compare with bad cat. If you're near york you're welcome to give it a try.
    Totally agree with this @StuartMac290 ;
  • pmgpmg Frets: 298
    My black cat 30 is a 2013 I think.  Don’t think that it’s k master (unless it’s an earlier incarnation before it was branded as such) bu5 the master volume is decent on it.  I had a 15r which I’d use wide open but I missed the oomph of the 30 and sold it  :/
    my classic deluxe runs wide open (no master volume fitted). I also tend to run a matchless lightning wide open when using one
  • slackerslacker Frets: 2217
    edited June 2018
    The matchless or bad cat 1x12 combo is a great choice and portable for most bands, but is going to run out of clean headroom in a  very loud band. I have a matchless 15w head. I run it with a 1x12 marshall with an ev or a 2x12 tone tubby alnico theile open back hybrid. The tubby don't beam.
    I don't know if you can add another cab to the combo.
    I also have an early bc30 2x12 that stays in 15w mode most of the time. Again and imho its the two speakers that provide the bigger sound. It's too much amp for me really but I don't need to sell. I wish it was lighter.
    ...said every 2x12 Bad Cat combo owner ever! ;)
    There's definitely a noticeable difference in feel between the 15w/30w mode. It's all personal presence but i leave mine in 30w most of the time. Mine's a 2002 and full of Matchless branded parts, I wouldn't say the Master was bad though to be honest but I haven't tried a K Master model to be able to compare.
    edited June 2018
    @miserneil ; Do you have the master circuit in or out?
