HX Stomp
  • sgosden said:
    https://www.thegearpage.net/board/index.php?threads/line-6-hx-stomp-video-answers-to-all-your-questions.1981427/
    stealing the data leaks from TGP
    Edit - video taken down before it could be watched :(
    I watched some of it - not particularly exciting, and it had a lot of really annoying background noise.
    "Mains is ouchy if you get it up you" - Sporky
  • CabicularCabicular Frets: 2213
    Sporky said:
    It's adorable!
    Oooh. How about two of those in the loops of a Helix?
    I was thinking along similar lines
    juat offloading 1 amp and cab block to a seperate DSP would give me a bunch more room
  • sgosdensgosden Frets: 891
    Sporky said:
    It's adorable!
    mini helix controlling the Amp modelling, with big helix as a massive everchanging pedal board? sounds pretty wow to me!!
  • KebabkidKebabkid Frets: 1696
    I've toyed so much with whether or not to get a HX but this one really appeals
     www.cairoeast.co.uk - Madness Tribute band (Bass Player) and guitarist elsewhere
    Feedback - http://www.thefretboard.co.uk/discussion/57885/
    0reaction image LOL 1reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
  • BintyTwanger77BintyTwanger77 Frets: 1389
    edited October 2018
    Ooh, the link in the original post doesn't/has been taken down now, and TGP thread above has gone as well..
    Did someone in marketing shoot their load prematurely?
    1reaction image LOL 0reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
  • Ooh, the link in the original post doesn't/has been taken down now, and TGP thread above has gone as well..
    Think so! Not that it matters now....
    Ol' frank on TGP suggested the relase was about 12 hours early and that Dig-igloo will be sad
  • Oops. Too late now, we all know about it.
  • Actually...scratch that.
    On the back, we have this:
    On the left side, there are MIDI IN/OUT and headphones. That leaves three jacks on the right - two are TRS jacks for the stereo loop, which leaves one jack...since logic dictates it won't be an expression/FS jack (the other Helix units only have one), it can only be the Ext Amp out.
    In which case...even though it's limited to six blocks, I'm thinkin' this could be a winner.
    I know this will be shot down in flames but I my opinion that doesn't look as good as the headrush in terms of use and practicality.
    I also find it interesting that those that were berating the Headrush for a lack of switches are swooning over this which has even less switches.
    1reaction image LOL 0reaction image Wow! 1reaction image Wisdom · Share on Facebook Share on Twitter
  • so is this a modeller or not??
    My trading feedback
    yes
  • digitalscreamdigitalscream Frets: 14577
    edited October 2018
    It does have less switches by default, but you can add another two using the FS4/5 jack on the back. Five is just enough for me.
    However, this is far too limiting for my needs as it turns out. Only three snapshots per preset, and it turns out that I need a minimum of 8 available blocks. And then the lack of Ext Amp output...I'm out, I'm afraid.
    Great as a "get you out of the shit" unit in case of emergency, but not much use as the basis of a full-blown rig IMO.
  • NelsonPNelsonP Frets: 1079
    edited October 2018
    So Atomic start with a 3 button model, then launch a unit with 12 and a cut down version with 2 and then decide 6 is best.
    Headrush start with 12, then decide to launch a unit with 4.
    Line 6 start with 12, then launch a unit with 3 (and also an FX only version with 8 buttons in the meantime).
    So if you need to choose between them, just decide in advance how many buttons you want:
    2 = Atomic Amplifire box
    3 = Line 6 HX Stomp
    4 = Headrush gigboard
    6 = Atomic Amplifire 6
    8 = Line 6 HX FX (athough you will need an amp too)
    12 = the choice is yours!
    ...and there's an obvious gap in the market for a 10 button new gen modeller.
    3reaction image LOL 0reaction image Wow! 2reaction image Wisdom · Share on Facebook Share on Twitter
  • What's a "snapshot" in this context?
  • John_AJohn_A Frets: 2248
    Agree - I would have liked more switches (4 would have been good, 8 would have been lovely) but the reason I'm swooning is it's a Helix based thingy, so I know it will sound good and fit in a gig bag as a backup.  The Headrush looks good to me, but it's a faff on using two different platforms.
    Suppose the reason it's so stripped down is if it had much more then it would practically be a LT in a smaller format which would have affected LT sales.  Looks great, but my ideal would have been something slightly bigger with more footswitches
    Do me a favour and like this:
    https://www.facebook.com/MarkedCoversBand
    It certainly is
  • Am interested as both a Full Fat and LT are too expensive for my usage but would need to know more about what it's capable of.. (and why others find it limiting...  what is an Ext Amp for?)
    My trading feedback
  • SporkySporky Frets: 15060
    Basically it's a sort of sub-preset.
    So if you had a patch with a wah and an overdrive and a delay, a snapshot could recall a particular gain and level for the overdrive, while also changing the delay settings for an epic widdly solo, but it wouldn't do anything to the wah.
    So you can recall any set of parameters for any of the blocks in the patch, and leave all the others unchanged.
    Every year, I grow half as pretty, and twice as drunk.
    Ext Amp would be for switching channels on a guitar amp.
  • preston61 said:
    Cabicular said:
    preston61 said:
    It also has a headphone output, something the HX is missing
    I’m not sure why you would have a headphone socket on an FX unit? Makes sense in a modeller though
    Probably just me who needed it when I had the HX (I don't play in to an amp, just a mixing desk, so at home a headphone out would've been helpful)
    A Google image search for HX Stomp shows the headphone socket on the left side panel, beside the MIDI sockets!
    Click here for my Trading Feedback
    OK, I can understand why that would be omitted on a skinny modeller
    My trading feedback
    Socket on the back labeled FS 4/5  If that does what I think it could I could happily gig with this
    What do you think it does??
    My trading feedback
    Hopefully it instantly transforms your playing into something that other people actually want to hear. If that's the case I'm in too.
    Cool thanks.
    I sort of do that with my POD HD already. Create a patch and copy it on four pedals ABCD, then tweak each one so there are four variants.
    Im hoping that all footswitches (1-5 including the 2 external ones) are assignable, so my core patch would be clean, crunch, dirty, lead with FS 4 for delay on/off, that would get me through 90% of a gig and then a few patches for the songs that need something different.  At a push I'd get through a gig on a single patch
  • TrudeTrude Frets: 432
    Did anyone else notice the 3A power requirement? That's going to make it a pain to integrate into a pedalboard.
    Trading feedback here
  • I'm playing bass at the mo, and my LT is overkill for it and the guitar player is now using it. I can get by with a zoom b3n, but I'm interested in this now. Whether it's worth the extra expense is another thing. Shame there is no XLR out... Missed a trick there.
  • If it will do "clean" -> "Heavy crunch" -> soaring lead.. I'm definitely interested...
    although I'm not into FRFR, it doesn't appeal; so it'd be Baby bomb into a Cab...  unless i fancy a PowerCab..
    wonder if it will use IR's too??
    My trading feedback
    Pretty sure the original link said it supported IR's, but if you are using a Baby bomb into a Cab then surely you wouldn't need them
