Its come up several times on TGP.
https://goo.gl/images/Vecc53
In my defence, I have a tendency to use the knock offs as a "try before you buy" type of thing.
I've done that a few times (I bought a Joyo Ultimate Drive before buying an OCD then decided to invest the real thing because I liked it what I heard).
Heard a lot of good things about the Amp 11 so this would be my way of seeing if I like the flavour before splashing out £100+
I'd say the Timmy is the original transparent overdrive, and the Amp 11 is like a modded version with a slight mid-boost.
