Doubling Bassline with Guitar
thegummythegummy Frets: 4389
Anyone ever done this for a record? Just played exactly what the bass plays but an octave higher on a guitar?
I got the tip from a session guitar tutorial video so just tried it out - it was weird, it felt so much like using an octaver pedal, my brain couldn't disconnect the already-recorded bass part from the guitar I was recording at the time.
Sounds kind of synthy really, makes a massive difference but not sure if I like it on my first attempt.
Any tips for doing this or how it's mixed? Tone/guitar/pickup settings etc.?
  • richardhomerrichardhomer Frets: 24793
    Panning them hard left and right while recording the part will allow you to mentally ‘seperate’ them. Funnily enough, I’m doing the guitars on a friend’s project at the moment and he asked me to do this on a section of it. We both agreed it was ‘too much’ listening to it back - though in some genres - metal obviously - it’s a pretty standard arrangement technique.
    edited October 2018
    @richardhomer ;; (hi!) is right. Some 3-piece blues-based outfits did it. Maybe the guitar would start a riff, then the drums join in next time round, and the bass piles in after that. Possible examples include The Groundhogs.
    PS you will find instances in George Handel's music where the double basses play what the cellos play only an octave lower. I'm not sure it is new ;)
  • I think on the Making of Aja video Becker and Fagan refer to it as "the Nelson Riddle trick". Or maybe Mancini or another of those classic arrangers. I've found it works best with palm muting, to bring out the bass rhythm. It ought to kind of disappear.
  • EricTheWearyEricTheWeary Frets: 16254
    It's a pretty common thing in blues, punk rock, heavy rock, a lot of country, a lot of ska and reggae. Certainly in Jamaican music it's palm muting.
  • FunkfingersFunkfingers Frets: 14323
    Fairly common recording practice - when deemed necessary.
    If palm muted, the guitar contributes a transient attack that a finger style bass part played on flat wound strings may lack. It can reinstate the definition that might go AWOL when an analogue multi-track recording is mastered to analogue stereo then and, then, cut to disc.
    Be seeing you.
  • Led Zeppelin did it a fair bit, especially just before a big solo where the guitar then splits away from the bass once the general gist is established.
    More modern examples would be Muse and Royal Blood (though in the case of the latter, it is of course more automated with octave pedals and a whammy).
    On the other hand I quite like double tracking a solo an octave lower for a bit of variety, although again it's easier to use the octave down/octave up setting on the Whammy to do it when not recording
    soundcloud.com/thecolourbox-1
    On latter day LZ albums, Jonesy often played an eight string bass - especially on songs where he was the main composer.
    Be seeing you.
  • Before the other guitarist left my band we used to cover lets dance, he would play the Nile Rodgers part and I doubled up the bass part on guitar with a fairly dirty sound and slighly muted. Sounded great and very punchy.
    I think that when the instrument was first introduced in classical, it would always play the bass line (played by cello or other instrument) an octave lower rather than having its own part and that's why it's called the double bass.
    The fingered flats thing is exactly what I was thinking it would be useful for and what I was testing it out with. I wasn't muting though, will need to try that.
    Would the palm muted guitar part be played clean or distorted?
  • Phil Spector used to double the bass with palm-muted baritone guitar to get more presence on the bass part; he called it 'Tic-Tac'. I don't like it when the guitar is dominant; it sounds like a guitar and a bad octaver... however I LOVE it when the bass is dominant and the upper part is simply reinforcement.
    That's usually referred to as Tic Tac on old country recordings so I presume he would have taken it from there.
    Always seemed interesting to me that the country style doubling thing is used on ska recordings and I assumed it was coincidence but, apparently, in the late 50s, early 60s in Jamaica you could pick up radio stations from the American southern states so country music was widely heard.
    In reggae doubling the bass line with a clean palm muted guitar part is known as tracking. By the 70s it pretty much comes to an end but what you get is a muted guitar part that's played as a counter rythmn - almost a second bass line. On a lot of Bob Marley recordings for example.
    When you say "it's known as tracking" is it that they use that term to specifically man that or are you making a point that it's a thing done on every single record of that genre?
    Lot of musical terms unique to reggae ( and completely unhelpful for anything else) and doubling the bassline with a guitar part is known as tracking apparently. Quite hard sometimes to know what is going on with old ska and reggae recordings but it was very, very common as it had been in country. Really just to help give basslines some audible definition from the days when flatwounds ( or even double basses on country recordings ) where standard.
  • prowlaprowla Frets: 4896
    I think it was done on Roundabout.
  • p90foolp90fool Frets: 31368
    Here's a good example of using a clean guitar to add attack to a bass line;
    Loads of great comments, thanks.
    Any thoughts on guitar type, neck or bridge pup etc.?
    It's also done on Lazaretto.
  • menamestommenamestom Frets: 4641
    Works for Vulfpeck
  • It's also done on Lazaretto.
    Oh yes oh yes
