Both of these items work as I can get a Data Dump from the ME5 to the APP (but seemingly no apparent way to save it) so I know the signal path is working. When I press the patch change on the ME5 the app relays what data it has been sent, but it is sending back to the ME5 that seems the problem. I think it must be a state I have to put the ME5 into to allow patch changes, but I cannot seem to get the right combo of settings on its front panel...
Another point worth mentioning (for when you get them talking to each other) is that some devices use PC numbers 0-127 and some use 1-128, so you may find a discrepancy.
Another possibility is that you need to send a Bank Change message before the PC message.
Sorry, that's me out of ideas now!
I suppose I need to rig up my old Atari with it and load the songs that had the patch change data entry saved in them to see what I did... back in 1991 !
