Last time I did one I used a sharp wood drill bit and some masking tape.
I don't have one, although I probably should get one. It would pay for itself in two fitting jobs.
I've found their 8mm to 10mm machinehead borer is another example of something that looks expensive but does the job so well and easily it seems worth every penny when you've used it once.
