I'm still getting to grips with it. I did find there were a couple of patches with some weird parallel blocks in place that sounded terrible until I removed them.
Does anyone know if I can connect the expression pedal with a standard mono cable or does it need a TRS cable?
Got my first show with mine coming up next Friday.....I'm basically using it as a stomp ox and got rid of a few pedals from my board, with a dedicated patch setup up should my amp fail!
After my initial misgivings, I must say that I'm loving the sounds, some of the drives and modulation effects are fantastic.
Anyway, I'm looking to now better integrate it with my other pedals, as basically I prefer the sound of my own tubescreamer, whammy, crybaby and Way Huge Aqua Puss.....
Would it be possible to use a boss es5 or 8 to switch stuff via midi on the hxstomp as well as adding in selected stomp boxes too?
In addition to the preset banks it appears 2 banks can be user programmed for PC and/or CC commands. Only one command per switch and latching only not momentary, and limited to only one midi channel.
Also has connections for 2 expression pedals. Powered by AAA battery or via USB.
The manual's here.
You can't set the cc# sub parameter . You can only toggle between 0 and64 (on/off)
So for example if you wanted to control snapshots using this
you can only Select SNAP SHOT 1.
Probably one of the things people would like to do.
If this were possible the controller would be perfect and of course you may be happy to not have this function available
Edit: but yeah looking out for 2nd hand MC6 is probably a better bet.
Also note that you can only power it via battery or USB.
Slightly restrictive for calling up snapshots from other patches though, but can work around it if I really tried to figure it all out
From a line6 thread on IR.
Question for HX stomp users and, more broadly, modelling users. Have you experienced this ''new world" and what does it sound like? In other words, what can you do tonally, with a modeller that is simply not possible with a traditional combo/stack (leaving FX aside).
I was having a play tonight and was getting exp 1 and 2 both controlling each other’s assigned parameters.
Also a momentary footswitch would only engage briefly on release.
Any ideas?
Has anybody downsized from an LT to a stomp to integrate back into a pedalboard?
I’m thinking of doing so as I use my small pedal board more but like the Helix as a recording and backup option. Plus although I generally prefer pedals a ‘Swiss army knife’ option of the stomp would be good.
Just seems a big jump in functionality, trying to work out if I would regret it.....
