I think I'm most looking forward to the Hudson Broadcast and most worried about the Phase 90. I have built a little FET tester and matched the transistors as closely as I could from about 12 options but I'm not sure how close is a "good" match.
That graphic looks excellent - paint pens?
yep posca pens, with some farrow and ball Calluna for the background. Got a sample pot of the colour we want to do the bathroom in knocking about so thought I’d put the rest of it to use in this cost of living crisis. I went with powder coated white cases for the stewmac kit but it turned out to be too slick for the posca pens. Scuff sanding a key did the trick but had to cover that up somehow
I had thought the easiest way would be roughing up the existing paint, enamel spray paint, water decals printed on my cheapo ink jet printer, then clear coat.
I haven't settled on a design but currently my ideas are things like this...
Does that seem sensible/likely to succeed?
You’re plan will probably work but I never had great results with spray paint. If you have the kit/ability to drill, then you may be able to get a powder coated new enclosure for a similar cost (or less) than the paint. You could then do your water slide and clear coat or use envirotex or similar epoxy on the top (guide earlier in this thread by Phil).
I've been using a fixed wah + doubler effect together for my lead sound so I'm putting the two effects in one box with one switch
The off board wiring is all done
Another pedal I like listening to but not looking at is my Behringer ADI21 - truly hideous. I'd like to respray it (with an adhesive promoter, then enamel paint), but it looks like water decals might not take to that textured finish. Can anyone suggest some means of applying neatly finished labelling?
