DIY solution for altering pickup cavity routing
jaymenonjaymenon Frets: 815
edited May 2019 in Making & Modding
I have a Telecaster originally routed for a Wide Range humbucker.  I'd like to use a conventional humbucker though...
The problem is the distance between the pickup legs / mounting screws.  The traditional humbucker being slightly narrower, the routing for the legs and screws of the will need to come in by about 5mm on each side.
The pickup cavity is routed with the deeper furrows at the edges 87mm apart, and the legs/screws of my traditional humbucker  will impinge on the central (relatively elevated) flat floor of the pickup cavity.
Inter-Mounting Screws Distance
WR Humbucker: 87mm
Conventional Humbucker: 77mm
Short of getting it properly routed, is there a simple DIY solution please?
In the picture, I've fitted a pick guard that's the correct size for a traditional humbucker (there's a bit of an overhang). But there's wood in the way of where the pickup legs / screws will go.
Expert opinions deeply appreciated...
[Imgur](https://i.imgur.com/rKsLQRi.jpg)
Jay
  • poopotpoopot Frets: 9099
    Chisel?
  • Winny_PoohWinny_Pooh Frets: 7768
    edited May 2019
    Drill a single hole where the screws go. You have lots of wood behind there. Mark depth on a piece of masking tape on the drill bit.
  • NPPNPP Frets: 236
    and if the hole isn't quite in the right place, drill another one. As long as it doesn't end up looking like my Strat here: http://thefretboard.co.uk/discussion/comment/382548/#Comment_382548 you'll be fine - but even there all the sins are hidden under the pickguard.
  • ICBMICBM Frets: 72300
    As already said, if it's just the screws that will hit the wood you just need to drill two holes to allow them to go in further - make them quite a lot bigger than the screws so placement is not critical and they don't try to tip the pickup at an angle.
    If it's the feet of the pickup base itself it's a bigger problem and you will need a chisel, small mallet and a bit of care to chop out the right shape recess.
  • jaymenonjaymenon Frets: 815
    Thanks chaps for all your useful observations and suggestions...
    A sharp chisel and a mallet it shall be...
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8823
    I’d sooner find a friend with a router than take a chisel to it tbh.
  • FunkfingersFunkfingers Frets: 14422
    There is an argument for enlarging the cavity to the same proportions as the one-size-fits-all rout found on the Fender MIM Standard Telecaster. That way, any pickup change you desire in future requires only a scratchplate change.
  • MLten80MLten80 Frets: 162
    edited May 2019
    +1 one on the pal with router.. where are you based? there could be a FB'er near you :0
    I'm in Gorleston - actually Rexter is a good friend and lives about 30 miles away, and he's been very supportive.
    It's just that he's very busy and I don't wish to bother him with silly little jobs when he's doing far more serious re-finishing work...
    If you're at all competent with tools, doing this with a chisel is a lot easier and almost certainly safer than doing it with a router.
    edited May 2019
     Thanks John -  that’s very reassuring for me.
     I’m an eye surgeon, I think I’ll be okay...
  • TTonyTTony Frets: 27453
    You've probably got this sorted by now, but if not (and if you're around over the weekend) you're welcome to pop over.
    Thanks Tony for your kind offer - all sorted now :-)
